my evo x build
Old Jul 13, 2012 | 01:44 AM
joeyhauser's Avatar
Originally Posted by Mr.Nine
So i'm not aware of how x's are set up at all, are they belt driven or chain driven? And if not chain driven what is that chain for if I can ask! By the way sick set up and build!
That's the timing chain
Old Jul 13, 2012 | 05:54 AM
paulekas's Avatar
it has timing chain if that's what you asking
Old Jul 13, 2012 | 05:55 AM
paulekas's Avatar
Originally Posted by Alpha X
How did you fit those wide tires
wide body kit that's the only way other wise prb 275 widest you cant put
Old Jul 13, 2012 | 06:12 AM
vegittoss15's Avatar
Lol, doesn't the manual clearly state that a staggered setup is awful for the drivetrain?
Old Jul 13, 2012 | 06:23 AM
Supraboy1's Avatar
Yes, extremely bad for it. I'm just confused why someone thinks you need tires that big on an AWD car.
Old Jul 13, 2012 | 07:50 AM
paulekas's Avatar
I am sure it wont be bad because tires went inside by 2 inches not outside wheel bearings will be fine when I test drove it it handles 5 times better than stock almost like a go kart
Old Jul 13, 2012 | 08:46 AM
Supraboy1's Avatar
335/35/19 rear 275/40/19 front creates a variance of a little over 2% in different wheel spin. Not good for an AWD car. At least got the same overall size tires and wheels
Old Jul 13, 2012 | 09:21 AM
paulekas's Avatar
It's about 1% difference so its ok for awd also why Audi r8 has different size tires like 235s and 285s something like that and runs fine?
Old Jul 13, 2012 | 09:33 AM
ZLAYER's Avatar
I put on a different brand (same stock size) tires on the rear of my car and got a awd service message at 80 mph. Then I bought 2 matching brand tires for the front and the problem was solved. The car is very picky so don't be surprised if it doesn't work.
Old Jul 13, 2012 | 09:34 AM
ZLAYER's Avatar
They are set up that way from the factory, so that's why they work. GTR also has a staggered setup.
Old Jul 13, 2012 | 10:08 AM
paulekas's Avatar
I am sure ill be fine 1% difference it just makes me laugh when ppl say it won't work why do you think we have differential in our cars? So that every wheel can spin at different speed put your car to rally on dirt 4 wheels will spin at different speed and nothing will happen same as i have 1% and 5 pounds difference in wheel weight nothing happens....
Old Jul 13, 2012 | 11:18 AM
ZLAYER's Avatar
I hope it works for you. I will reiterate, I used the same size, but different brand and had problems. The guy that mounted the tires told me I hafta do all 4 at the same time and I thought he was full of it. I measured the diameter with a tape measure and didn't find any difference in tire height. But sure enough I got, lights on my dash the first week.
Old Jul 13, 2012 | 11:50 AM
paulekas's Avatar
Interesting if the same size just different brand should be ok.... And if ill have problems ill put 335 in the front
Old Jul 13, 2012 | 11:54 AM
Kracka's Avatar
Different brands rate/measure tires differently. For example, one 225 wide tire can actually be wider than another 245 wide tire. Hell, sometimes this can even vary between different models within the same manufacturer.
Old Jul 13, 2012 | 12:06 PM
paulekas's Avatar
Yeah I guess u right ill try to put back wheels on the front ill see if it fits and if it does ill put 335 tires on the front
