Middle of the season Build!
Old Aug 2, 2012 | 09:17 PM
FathouseFab's Avatar
Finally got a little more time to work on my pile. Fired it up and started the break in today. Hope to test it before the Shootout in a week or so.
Not much cool fab work, Other than the new engine its basically the same as last year.
Feels good to hear it run again. She revs fast for sure!
Fathouse
Old Aug 2, 2012 | 09:25 PM
Blue91lx's Avatar
Sick!!! What kinda ponies you hopin to make?
Old Aug 2, 2012 | 09:53 PM
batty200's Avatar
Badass ! I am sad I missed your call if you were calling to let me hear this beast! I am hoping my Crower rods stand up to my 6262 better than your did to the 6765!
Old Aug 2, 2012 | 10:00 PM
Adam, I was calling to tell you about the 6466 car I did!
Old Aug 2, 2012 | 10:45 PM
4g63evoeight's Avatar
Love how you welded the balance shaft hole shut!
Old Aug 2, 2012 | 10:53 PM
bostonhatcher's Avatar
+1
Was that a Howard rod you bent? You know the engine is supposed to fire at TDC right?
If you look at what the bearing did to the big end of the rod, it doesn't matter what rod you run now it won't save the bearing under the same circumstances.
Old Aug 3, 2012 | 06:57 AM
batty200's Avatar
Originally Posted by bostonhatcher
+1
If you would use your eyes and brain before you spoke you would realize there is no bearing in that rod and since the bearing is perfect as was the crank there was no reason to make these negative comments.
Old Aug 3, 2012 | 08:09 AM
+1
There was nothing wrong with the tune in this car and nothing wrong with the big end of this rod. I know how to build and tune these cars. It was bent simply by to much power/cylinder pressure.
The rods where crower btw not howards.
Fathouse
Old Aug 3, 2012 | 08:10 AM
Better than a freeze plug!
Old Aug 8, 2012 | 07:36 AM
Takin the car to the track tonight to get some seat time in before the shootout. Hope all goes well!
Fathouse
Old Aug 8, 2012 | 07:44 AM
AngryEvo8's Avatar
Fathouse
Goodluck letttter rip and get vids!
Old Aug 8, 2012 | 08:03 AM
Evosick2332's Avatar
Good Luck Bud! Get some videos!
Old Aug 11, 2012 | 04:17 PM
Went to the track today, I'm having some clutch issues and will drop the trans out tonight or tomorrow to see whats up, but anyway the first pass it bogged out of the hole and I ran it out to get a good log and it went 10.8@ 147
The next pass I got it to launch "ok" but it was only a 1.8 60 and it went a 9.78@149.5
Our local track is pretty strict on the rules, they warned me after the first pass and booted me after the second.
Once I get my clutch figured out and can get back into the 1.4x 60' range it should fly!
Boost was right over 40psi and this car is still ~3200 with me in it. Still has heat, power steering etc etc.
I got a few vids I will post up in a bit, but here is a few pics for now
Fathouse
Old Aug 11, 2012 | 06:18 PM
talon91guy's Avatar
Car is definitely rolling out! What will the boost be set at for kill mode?
Old Aug 11, 2012 | 07:32 PM
Wherever it stops making power. The tune is a little soft and I was def driving easy/shifting easy.
If this thing goes 155~ I will be real real happy. The car (and driver ) is just to damn heavy!
Fathouse
