Badev0's Build Thread *Part 2*
Old Sep 30, 2012 | 06:51 PM
  #76
badev0's Avatar
Originally Posted by Liqquid
it was the older purple colored one, on an evo.. extremely lightweight clutch
Ah okay, I haven't seen that one before.
Originally Posted by StreetThisEvo
I love putting motors back together!
Any progress on the wiring harness?
Ive moved a couple things to run off right at the firewall, map sensor and knock sensor. I removed a good amount of plugs and wires that weren't needed, then I lost motivation lol.
Old Oct 6, 2012 | 09:06 PM
  #77
badev0's Avatar
Got the motor assembled 100%. Was thinking of putting the motor/trans in the car but for some reason QM doesn't include the bolts to bolt the throw out bearing to trans... Going to grab some from the hardware store tomorrow...
Didn't take as many pictures as I wanted but here's what I have.. All bearing clearances are spot on to what the machine shop told me.
Crank dropped in
Rods/pistons/rings assembled. Rings were filed before this already.
Crankshaft end play within spec
Pistons/rods installed and TQ'd. Rod bolts torqued with the included Manley lube. Stretch and recommended torque both spot on.
Headgasket/MAP H11's. Applying the included lube for the studs before spreading around the threads.
Head on a torqued
Timed and mostly together
All together
Daily driver
Old Oct 7, 2012 | 06:28 AM
  #78
jeffbeagley's Avatar
Lookin good bro!
Old Oct 7, 2012 | 01:30 PM
  #79
badev0's Avatar
Originally Posted by jeffbeagley
Lookin good bro!
Thanks man
Old Oct 7, 2012 | 01:33 PM
  #80
badev0's Avatar
Bolt solution for the throw out bearing
Good bolt length
Installed. I used blue loctite on the threads.
Some one asked for pictures of the plates and discs of this clutch so here they are...
Disc 1
Plate 1
Disc 2 > Plate 2
Ready to go in the car.
Looks good. No shims required for stock crank.
Cell phone pic of the manifold/turbo mock up
Old Oct 7, 2012 | 02:48 PM
  #81
StreetThisEvo's Avatar
Make sure you stagger the clutch disc so that the holes don't line up with one another.
Looks great so far. I think I bought the same bolts from ACE Hardware when I did mine.
Old Oct 7, 2012 | 05:55 PM
  #82
tscompusa's Avatar
very nice looks awesome! new setup is going to kick ***
Old Oct 7, 2012 | 06:45 PM
  #83
600whp S4's Avatar
sooooo sick scott
Old Oct 7, 2012 | 08:07 PM
  #84
badev0's Avatar
Thanks guys. Everything is coming together very smooth. Put the motor in a little while ago and got the manifold/turbo installed so I can start to fab the LICP and the downpipe.
Ignore the crappy valve cover. It'll be glossy or maybe wrinkle black before it runs.
Making sure things are good..
Pic for you Tom. No way in hell you would be able to run any kind of filter if you bought this manifold lol.
Old Oct 7, 2012 | 08:25 PM
  #85
CurseDSM's Avatar
Originally Posted by badev0
Your forman don't look to happy about the job there Scott. He found somethin he doesn't like that you have to fix
Old Oct 7, 2012 | 09:40 PM
  #86
Evosick2332's Avatar
Looking good Scott! Can't wait to see it all buttoned up Do you still plan on getting out to the track once more this season?
Old Oct 7, 2012 | 09:58 PM
  #87
Hassan's Avatar
Nice build,,, alll the best
Old Oct 8, 2012 | 07:50 AM
  #88
badev0's Avatar
Pretty sure he approves of all the work
Thanks man! Should be up and running next week. Just waiting on a few random odds and ends to come in.
I won't be racing it until spring I'm pretty sure. Need to buy my new wheel setup which won't be for a while lol.
Thank you
Old Oct 8, 2012 | 08:45 PM
  #89
Jetfixrguy's Avatar
Curious on the compression ratio...., sorry if it was posted and I missed it, looks to be a killer build. Good luck with it!
Old Oct 9, 2012 | 01:03 PM
  #90
badev0's Avatar
Compression ratio is 10.5:1
