Beast Mode in effect. 2.3L 6766 "Build Thread"
We have been fighting electrical problems for a minute and haven't had a chance to throw some "E" in it. Finally have found a solution but awaiting a new engine harness. A certain shop from Orlando Florida whom had previously worked on the car did a number on the harness. Not going to name any names but he definitely has some funny YouTube vids from Regarding too much timing *hint hint*
Lol post up what I should search to find this shop you speak (or not speak) of.
im also wondering what was done to the block in order to make it rev higher than a normal 2.3, as im sure the extra rpms help a ton with that turbo. Whats different from just a regular 2.3?
Thanks
josh
Thanks
josh
Well men after a lot of hard work and countless hours of *** pain by the guys at the shop she is do e and tuned on E85. Well E66 to be exact. Oh well once the summer time blend comes back she will be back in for some more. Made 672/522.
So the 6766 failed on me. Was doing a check over and found that the turbo has some shaft play. Didn't even get the chance to take it down the 1/4 mile and put some times down. Pretty upset with the precision turbo filing with maybe 1k miles on it including dyno pulls.
Definitely going with a forced performance turbo next. Definitely going to boost it with a Super94
Also since it's been down and sitting in the garage been doing some work to it. Polished the upper inter cooler pipe, inter cooler end tanks, ac lines, pretty much whatever else I could polish. As well as added an ipad mount for the interior. Also put a carbine 6 point lower brace on, white line front sway bar, and widened out the front fenders so I can lower it more and have more room for fatter tires.
And here's a pic from a cruise.
Clean. I hear the journal bearing big precision turbos fail a lot. Go 6466 bb you will love life. The super 99 is a massive turbo I doubt you will see it's full potential revving less than 8500rpm.
Also pte is releasing a bb 6870 which is supposed to compete with super 94/99 you might want to wait for that.
Bugger to hear about the turbo, but sounds like a wicked upgrade underway! Be interesting to see how you find the Super94, hell of a large turbo for a street setup.... should be intense once it's running though. Let us know how you find it
Added a Buschur Racing Quick Release Harness Bar with Sparco 3" Harnesses as well as fire extinguisher just in case. After Smurfzillas car burned up I'm paranoid.
Also have been training my Co driver/navigator.
