Evodan2004 has lost his mind part 3. The new changes and goals for 2013.
Old Dec 22, 2014 | 09:02 PM
  #1186
EvoDan2004's Avatar
Because a light weight subframe was not light weight enough.
I spoke to diamond a few weeks ago and requested if he would mind building me a lighter weight subframe then the already light weight one. So Dan went into some thinking and came up with what we are calling a "drag" version of the subframe. Please keep in mind. This is for minimal street use and mainly drag racing only. It is NOT for full on track cars that make turns. If your looking for one that can cover every type of racing then get the standard subframe. It is 3lbs lighter then the current one. My standard was 16.3 and the new drag version is 13.3. I am sure he could have gone even lighter yet but this is as light as he wants to go and feels comfortable with his name on it. Basically it is exactly the same piece as the standard version but it uses smaller diameter tubing and thinner wall thickness. Some may call me crazy but hey. The opportunity came up and I took it. Here are some pics
Got the standard one out
Side by side
And here is the drag version all ready to be re installed.
Old Dec 23, 2014 | 07:47 AM
  #1187
Sil'vr-Boi6's Avatar
Mind blowing...lol, you truly have gone down the rabbit hole. Subframe looks great btw, are both chromoly material 4142, if you're allowed to say?
Old Dec 23, 2014 | 03:49 PM
  #1188
EvoDan2004's Avatar
it is made of chromoly yes. what grade i do not know. i am sure Diamond will tell you if you ask.
Old Dec 26, 2014 | 06:18 PM
  #1189
mitsubeastlee's Avatar
delete the power steering!!!! loop the lines
Old Dec 26, 2014 | 09:17 PM
  #1190
EvoDan2004's Avatar
No way. I'll either be leaving it OEM or getting the electric power steering setup. But I have other things I'm planning that are tieing up my money.
Old Dec 26, 2014 | 11:21 PM
  #1191
Sir2egk's Avatar
Selling old subframe?
Old Dec 26, 2014 | 11:53 PM
  #1192
fimotorsports's Avatar
You should have sent me your control arms to polish
Old Dec 27, 2014 | 03:16 PM
  #1193
My buddy local is selling his VERY lightly used electric power steering kit, maybe 500 miles or less. I think it is for sale on evom, if you are interested I can PM him to get your lowest price. I would have bought it but I just deleted PS, no point in keeping it the car will be going straight 75% of the time.
Old Dec 27, 2014 | 04:39 PM
  #1194
EvoDan2004's Avatar
You can ask but I'm not looking to spend anything right now unless it is to good to pass up
Subframe is back on the car.
Old Dec 30, 2014 | 05:55 AM
  #1195
JTEVO2932's Avatar
Looking good! If you want to sell the old subframe let me know.
Old Dec 30, 2014 | 12:18 PM
  #1196
03whitegsr's Avatar
It would be VERY easy to come to with a different rear engine mount that connected to the subframe. This would eliminate the steel bracket that goes over the steering rack, the dog bone link with the bushings, and the 2 piece trans bracket. I swear, that's how mitsu even intended to do it as there are already threaded mounting bosses on the trans that would work perfect for it. Seemed like I added it up at one point and I was thinking it would save about 8 pounds.
Also, go to a manual rack and ditch the power steering for another 13 pounds. I'm running M/S on a 2400 pound car with a 14.5:1 steering ratio and it's very manageable even with 7.5* of caster. The Evo with 3.5* of caster and a steering ratio of 16:1 would be nothing in comparison.
Old Dec 30, 2014 | 05:30 PM
  #1197
EvoDan2004's Avatar
I asked them about making the rear mount integrated but he felt it was best to make it OEM compliant.
As for MS Idk. I been in an Evo with MS and I hated every bit of it. How do you change the ratio on a OEM rack? I was just gonna get the electric setup.
Old Jan 1, 2015 | 03:47 PM
  #1198
EvoDan2004's Avatar
New product. As you know I deleted my thermostat when I converted to a custom electric water pump setup. This left me with a big ugly thermostat housing. It needed to go but I needed something different then what is currently offered. So I contacted frontline fabrication and explained what I was looking for. I wanted something small and to be OEM sensor friendly. So we came up with this. It is 16AN in size and Uses a fragola 16AN banjo fitting. I had the sensors angled in the back to help hide them for a cleaner finish. It also lines up perfectly with my upper rad fitting for a nice straight shot. Next on my list is a custom engine harness and some other things.
Old Jan 1, 2015 | 04:00 PM
  #1199
flyingscot's Avatar
looks good
Old Jan 1, 2015 | 06:45 PM
  #1200
Evo_AK's Avatar
Veteran: Air Force
Hey Dan,
What are the benefits of running an electric water pump? I've seen a few threads talk about them, but hardly anybody run one. Just curious.
