Craig's 2.4LR build thread
Old Jul 18, 2013 | 12:52 AM
craig05evo's Avatar
After too much waiting I finally got my block back from the machine shop. I have most of the engine back together! Won't be long now.
This is how she sits as of 7/18/13
This is my battery relocation project finished.
Here is how I wired under the hood.
Old Jul 18, 2013 | 04:32 AM
MitsubishiJoe's Avatar
I like the terminal for the negative in the trunk. Any info on that?
Also what kind of fuse or fusible link is that on the positive?
I like the bracket for the fuse block.
Old Jul 18, 2013 | 08:50 AM
DsmGuy86's Avatar
This looks sick. I've been thinkin about sending my ef3 in to upgrade to the ef4 when I do my 2.4 so can't wait to see how this turns out good luck man.
Old Jul 18, 2013 | 01:32 PM
craig05evo's Avatar
Joe: I got the ground from a stereo shop, just a grounding stud and that is a circuit breaker on the positive, also from a stereo shop. Both are stinger brand. You can press the red button to disconnect the positive without taking the wire off. The bracket was just plate steel that I bent and cut.
Dsmguy: thanks, I'm looking forward to getting this thing buttoned up soon.
Old Jul 20, 2013 | 11:10 PM
craig05evo's Avatar
Update: 7/21/13
Finished my custom dash gauge, I think it turned out great.
Also redid my tails, also didn't turn out too bad.
Old Jul 25, 2013 | 08:52 PM
craig05evo's Avatar
engine is back together, just waiting on a break-in tune!
Old Jul 26, 2013 | 05:36 AM
PAdutch's Avatar
That dash piece is pretty sick man! I'll be watch for those engine numbers.
Old Aug 3, 2013 | 11:57 PM
craig05evo's Avatar
I got the break in tune loaded up and put some miles on the car. No major leaks, the oil looks good after the 30 mile change, but my new alternator was bad, took a while to figure out, so hopefully sometime next week I can get it to idle and drive better. This 2.4 sounds amazing, much different than my 2.0.
Old Aug 4, 2013 | 12:32 AM
IRISHEVOX's Avatar
can't wait to see the numbers!
Old Aug 14, 2013 | 09:06 PM
craig05evo's Avatar
Well, I have put about 200 miles on my engine. After swapping from 2150's to 1100's my car drives much better on 91. I am moving at the beginning of September to a city without E85 so I am really bummed about that. My 10.5:1 is not going to like the 91 octane for sure. However there is a local company that sells 98 octane racing fuel that I might be able to cut with 91 to make 93-94 octane for a decent price.
I must say, speed density on my 2.4 is great. My car runs really well and is pretty darn smooth compared to my 2.0. I hope that my investment can get me into the 11's on pump!
Old Aug 15, 2013 | 08:28 PM
DsmGuy86's Avatar
11s should be to easy on this set up man I hit 11s on my stock block and ef3 good luck man can't wait to see the results on this and how it spools the ef4
Old Aug 16, 2013 | 05:37 AM
Perrin crank pulley
I have driven this car for 30k+ miles with this pulley on, after I disasemble the engine, I will post pictures of how the bearings look.
I am curious on these pictures.
craig05evo
Apr 18, 2016 10:19 PM
craig05evo
Jul 21, 2014 05:42 PM
craig05evo
Nov 6, 2013 10:02 PM
craig05evo
16
Aug 23, 2013 09:03 AM
craig05evo
17
May 16, 2013 11:22 AM
