Evo IX MR build
Old Feb 3, 2013 | 05:08 PM
familymr's Avatar
Quest for 9'S on street tires build
Well guys this started out as a broken 6speed swap to a 5 speed and a head gasket change. That all changed as I took the car apart.
This is the reason for the swap. The car lasted a long time on all stock setup on a 35r agency power kit on 1450cc on e85. I pushed the car well past what I should of and it lasted. Here is a shot of the dyno of the carI knew what could happen doing this an did not care. I do a lot of roll racing v8 cars and push it hard to win. So the end result was a hg lifted and pushed water and I just happen to notice that 1 piston was not coming all the way to the top when I went to change the hg. So this started my total build to handle a 6466 and my run for 9's on street tires in the 150+ range .
Old Feb 3, 2013 | 05:33 PM
JTEVO2932's Avatar
So what are you going to do with the motor..stay with the 2.0 or go 2.3?
Old Feb 3, 2013 | 05:35 PM
familymr's Avatar
I'm going 2.0 for now. But thinking of a 2.4 LR setup for a back up
Old Feb 3, 2013 | 05:42 PM
familymr's Avatar
Here are a few shots of parts going together..
I went with oliver lightweights an 1400 hd 10.5 to 1 cr and a manley crank.
Old Feb 5, 2013 | 06:53 PM
familymr's Avatar
I turned down my balance shaft at work.pistions installed
Old Feb 6, 2013 | 09:57 AM
jrswann's Avatar
nice
Old Feb 6, 2013 | 07:00 PM
familymr's Avatar
well I'm moving on along. Studs installed and fully built head from headgames.head all tourqed down with map h11 head studs
Old Feb 7, 2013 | 02:41 AM
4drboost's Avatar
How much boost where running when the HG blew and how power were you putting down?
Old Feb 7, 2013 | 05:49 AM
familymr's Avatar
http://m.youtube.com/watch?v=mRm-fGbeJ_Y
Old Feb 7, 2013 | 07:11 AM
ILuvJDM's Avatar
very nice, I love shiny parts
Old Feb 7, 2013 | 04:34 PM
4drboost's Avatar
Link is not working
Old Feb 7, 2013 | 06:01 PM
familymr's Avatar
Old Feb 10, 2013 | 06:37 AM
familymr's Avatar
More goodies came in.
Old Feb 10, 2013 | 07:08 AM
oscarquinones's Avatar
looking man good luck with your project
Old Feb 10, 2013 | 08:14 AM
familymr's Avatar
Thanks its a lot of $ and work but its all worth it.
