A scrolling nightmare -> Evo 8
Old Mar 23, 2013 | 01:03 PM
Kevin Troy's Avatar
Ralli Art Sticker
Karbon Deckel
Wheels Hyper Zero 1 in dimmension 18x9, 5x114,3
Tires Dunlop SP Sport 235/40 ZR18.
[IMG=http://img181.imageshack.us/img181/6537/p3161623.jpg][/IMG]
Servis;
Wash
HELIX Motorsport Twinclutch
Washing again
New brakediscs
2 evo meeting
Tech info;
Active Yaw Control (AYC) is an automobile feature that uses an active differential to transfer torque to the wheels that have the best grip on the road.
Unlike traditional mechanical limited slip differentials, an AYC is electronically controlled.
AYC was designed by Mitsubishi Motors, first introduced in the Mitsubishi Lancer Evolution IV. It has been included in certain models of every subsequent generation,
and was also used in the VR-4 variant of the eighth generation Mitsubishi Galant sedan and Legnum wagon. Later developments led to S-AYC (Super-Active Yaw Control),
first introduced on the Evolution VIII, utilizing a planetary gearset which could support an even greater torque bias than the previous system. AYC and S-AYC have also
been seen in several Mitsubishi concept cars based on the underpinnings of the Lancer Evo, such as the CZ3 Tarmac and Tarmac Spyder, the Montero Evolution, the RPM 7000,
and the Concept-X.
Active yaw control is based on a computer-controlled rear differential which can actively split torque based on input from various accelerometers in the vehicle
measuring longitudinal and lateral g forces, steering, brakes and throttle position. Where ABS brakes are fitted they too are included in the input parameters.
It accomplishes this via two hydraulic clutches which can limit torque on individual axles. This system should not be confused with stability control systems which
utilize the braking system of a vehicle by individually braking certain wheels to rotate and slow the car (such as Electronic Brakeforce Distribution).
AYC is a performance-oriented system which aims to increase cornering speeds.
Few nice pic;
TUV/MOT;
fi80 exhaust;
Finished:
Twinclutch:
Light flywheel 4,8kg
1 of 2 discs
Old Mar 23, 2013 | 01:05 PM
Kevin Troy's Avatar
Walbro pump 255L/h;
Old pump;
New brakelines HEL Performance;
Hyper zero-1 rims polverised in white
Dyno run:
TEIN Rear Strutbar:
Washing again
HEL;
Electronic Boost solenoid...
Track-day;
II. dyno run
Turbine check;
Ultimative car wash
Old Mar 23, 2013 | 01:07 PM
Kevin Troy's Avatar
cut
Old Mar 23, 2013 | 01:08 PM
Kevin Troy's Avatar
Winter setup;
Eibach
Bilstein B8
Bilstein & Eibach
OEM KYB
Waxing
After aplying wax:
After wipeing wax:
Oil change
OBD Engine check - Clear
BOV Cleaning
Clutch adjustment
Be for
After (pic taken from evolutionm.net)
Viper Performance Silicon Hoses
Turbo
Washing
Enginebay dressup:
OCC
Old Mar 23, 2013 | 01:10 PM
Kevin Troy's Avatar
FP Black, Ceramic Ball Bearing 84mm, ported, 25PSI (1,7 Bar) Waste Gate
New Evo 8 Head with exhaust manifold and intake manifold
LCS
Oct 31, 2011 08:13 PM
upandcoming
Feb 21, 2011 08:37 AM
maperformance
43
Nov 9, 2010 01:51 PM
pug206
Sep 25, 2009 11:56 AM
