evo 9 build (MA DEVELOPMENTS) EFR 9180 from england
Mark
I have not tested back to back on inlet manifolds but the way the cars drive on multiple bodies they are worth every $ as the diff is night and day,
This car has electric throttle responce which is amazing for a car with such a big turbo,
Tech yes having throttle bodies in each inlet track can effect power output but this car has easily exceeded its power expectations at each step so very happy with the inlet.
Mark
Mark
How do you control the air bypass with these multiple bodies? do you leave them slightly open? what's your idle speed?
excuse all the questions, I am in the process of refining my idle speed to as low as possible on a large set up (AMS F1/70mm tb/2150's) and the air flow variation at low speed can def throw things off (IAC + BISS asdjustments...etc). Curious how you're doing it.
very unique and interesting setup!
Makes sense since you eliminated much of the lag in the air travel from the conventional placement of the TB.
The inlet has a exentric cam adjustment on the end to adjust the throttle opening.
Mark
I wonder if anyone in the usa has a jenvey manifold? I doubt it. it would cost 3000 to get one here. the only car I know that uses one is this efr 9180 effort. without any back to back test against a known inlet manifold, I doubt anyone would ever buy one to try. just same basic common sense though, this manifold would likely be a nitemare on a smaller turbo car. four 48mm throttle bodies would flow more than one 90mm body. so it would be like going full throttle on a 60mm body at just a 20% throttle opening. welcomed on a big laggy turbo. makes a big turbo "feel" more responsive due to the extra response you get from small throttle inputs. but you dont want that extra response on a small turbo. I hate 65mm body on a 2.3 red setup. its too responsive sometimes on 60mm body.
I would fit them to everything if people could afford them they are worth every $,
They also sell a DBW version so you can get creative on your throttle mapping it you wanted.
Mark
I take it you have not driven a correctly set up and mapped multiple throttle body set up then,
Mark
Mark
Mark
FS[Mid-Atlantic]: Endless Brakes-Whiteline-Tein
Voltexed
10
Oct 23, 2016 09:29 AM
FS[SouthEast]: FS: Sparco 4pt Red Harnesses BNIB S Florida
06MRV8Killer
Feb 17, 2016 11:10 AM
FS[Northeast]: supertech 85lb duel valve springs
sketchy mark
23
Jan 14, 2016 05:45 AM
