EVOlander
No not really. I like the sleeper status. In fact, I'm even going to put the stock exhaust on and just run a boost activated cutout on the downpipe.
Thanks though!
Thanks though!
Not on this build, this is much cooler!
The super charger was just a thought I had when I was thinking about picking up an outlander once. It had the 4g69 engine in it and I knew of a few people who ran a Ripp supercharger in the 4g69 lancer making 300ish HP. Figured it would be a pretty simple and interesting build.
Last year I was dead set on building an airtrek but somehow I ended up starting an evo wagon project. I have the entire airtrek exterior conversion and I just want to see the parts I collected go to use on a nice build like yours. If you change your mind the parts are here waiting
I started to make good progress on it a few weeks ago but got hammered at the shop again so progress halted as it had to come off a lift.
I've got a set of X GSR wheels getting powder coated a nice bronze. Hopefully I'll have time next week to get her back up on the lift and finish the fab work. The biggest problem I had was that I forgot that the twin scroll turbo kit I helped make way back when down at DTM was for an A/C delete car. I'm a fat boy. Fat boy needs A/C. Much pie cutting ensued and I'll probably have to end up welding it to the housing to clear.
Then I just need to finish up the IC piping and she's almost ready to breathe some fire!
Depends on if you are talking intercooler or turbo setup. I was referring to the turbo placement above the turbo manifold so instead of looking at manifold when you pop the hood, the turbo would be right in your face.
Finally back on her. Just finished up one IC pipe, need to complete the lower now. Hopefully I'll have key start by the end of the week.
