From the depths (fair amount of pics)
Old Nov 10, 2014 | 05:44 AM
  #46
Sil'vr-Boi6's Avatar
Great thread....but you probably have to change the foam out of those seats....I highly recommend it, since will be a dd.
Old Nov 10, 2014 | 04:00 PM
  #47
evo_pirate's Avatar
Yeah I actually did the foam portion of the seats as well, so they're pretty clean. These seats won't actually be going back in the car. I have a set of IX seats lined up to take the place of these.
Old Nov 10, 2014 | 04:17 PM
  #48
DSMolition's Avatar
looks like someone beat me to the clamp comment. Good Luck!
Old Nov 10, 2014 | 04:25 PM
  #49
milruner's Avatar
Good luck with the rebuild, cant wait to see it finished.
MIKE
Old Nov 10, 2014 | 04:45 PM
  #50
kdeome's Avatar
In!!
Old Nov 10, 2014 | 04:48 PM
  #51
codgi's Avatar
Good luck with the rebuild! Looks like a serious amount of work
Old Nov 10, 2014 | 04:53 PM
  #52
2theMAX's Avatar
Props to you on this! I hope you get out of it what you are looking for. Definitely a lot of work!
Old Nov 10, 2014 | 04:55 PM
  #53
Grayghost's Avatar
Can't wait to see how this turns out!
Old Nov 10, 2014 | 05:07 PM
  #54
Don Andretti's Avatar
Great build. Back from the depths. Looks like fun :-)
Old Nov 10, 2014 | 05:11 PM
  #55
a2stepawd's Avatar
Wow, thanks for saving the Evo!
Do you think the wiring is rotted?
Old Nov 10, 2014 | 06:50 PM
  #56
xXANCHORMONXx's Avatar
I'd toss the wiring for sure
Old Nov 10, 2014 | 07:08 PM
  #57
cmb70's Avatar
Anything that is foam I would never reuse. Mold can hide in places you could not imagine and it can be deadly. As far as the underneath, remove everything, many parts could be saved with some good old fashioned elbow grease. All bushings should be replaced. Any mechanical part can be disassembled, cleaned and then lubricated and put back together. Wiring harness may be your biggest issue but shopping at junk yards may help you find many ofnthe parts you will need. I would love taking on a project like that.
Best of luck and keep moving forward.
Old Nov 10, 2014 | 07:12 PM
  #58
shavkatjon2000's Avatar
Good luck with the build keep us updated
Old Nov 10, 2014 | 07:46 PM
  #59
gabzor's Avatar
i agree with this, although its a good thing you're using other seats, they look decent though on the outside!
i would think that you would have removed the foam and everything, but you're brave man, least you can make everything mil-spec and it should last a while
too bad your not somewhere you can work on it and have to store it in the winter.. i know im real spoiled with 90 degree novembers here
Old Nov 10, 2014 | 09:40 PM
  #60
evo_pirate's Avatar
Thanks all your support helps keep me motivated!
I'm not really sure just yet. I'll be going through the wiring here soon testing it and cleaning it. I'm sure it would be easier to just replace it but I'd like to salvage as much as I can.
None of the fabric that was in the car at the time of the flood will be going back in, including the sound deading material in areas like inside center console even the intake duct for the blower motor. Screw all that mold and bacteria
I'll be working on it during the winter the weather port is just too keep it out of the weather and because the shop is filled with a different project, '59 Apache.
