My EVO 8 aka War Machine daily driver/weekend warrior build!
Old Jul 17, 2015 | 08:37 AM
Stark_Tech's Avatar
If you guys routinely turn out evos with the same setup hitting 27lbs then I don't know why mine isn't doing the same.
Old Jul 17, 2015 | 08:42 AM
Fast_Freddie's Avatar
Veteran: Navy
That turbo isn't even really breathing at 24PSI... turn it up to 26-27ish and get it tuned and I am sure you will be much happier...
Old Jul 17, 2015 | 08:44 AM
06MREvo's Avatar
Same thing I said!!
Old Jul 17, 2015 | 08:46 AM
Veteran: Navy
BTW got the lifters BJ, thanks again!
Old Jul 17, 2015 | 08:47 AM
Stark_Tech's Avatar
But do you think it was left where it is for safety and reliability reasons? That's the only thing I can figure...
Old Jul 17, 2015 | 10:01 AM
ForceFedTuned's Avatar
Originally Posted by 06MREvo
Same thing I said!!
truth and from experience i would highly suggest checking to make sure since you have ID1000 injectors that are Hi-z that your factory injector resistor was deleted as I have seen 4 cars come in just like yours with the resistor still plugged up causing "issues" when they were tuned
Old Jul 17, 2015 | 10:05 AM
06MREvo's Avatar
No problem man!
I still can't believe people/shops are doing that....
Old Jul 17, 2015 | 10:20 AM
no joke Bj all 4 in the past couple months...same place...same "issues"
OP sorry for cluttering your thread got off topic a bit
Old Jul 17, 2015 | 10:23 AM
Stark_Tech's Avatar
I bypassed the resistor on the firewall myself before I installed the injectors.
I did a few pulls today, it hits 24 and tapers to 23 and holds it...
Old Jul 17, 2015 | 10:24 AM
Good deal
Old Jul 17, 2015 | 10:43 AM
Stark_Tech's Avatar
I want to research and find other evo's out there like mine with the same mods and see what they made for reference.
If anyone already knows someone or a link to a build or anything similar to mine feel free to drop it here!
Old Jul 17, 2015 | 06:26 PM
Stark_Tech's Avatar
Old Jul 24, 2015 | 11:28 AM
Stark_Tech's Avatar
Caught word from my tuner. He tuned on the safe side, because this is the range where it can be a little dangerous if you get a bad tank.
Old Jul 25, 2015 | 10:52 PM
Erik@MIL.SPEC's Avatar
Originally Posted by Stark_Tech
Received word from my tuner. It was tuned on the safe side, because this is the range where it can be a little dangerous if you get a bad tank of gas.
Evos like boost if you limit timing on pump gas. Guys are running 24 or 25 pounds out here on 91. That turbo should be able to handle more than 23 pounds on 93.
Old Jul 25, 2015 | 11:07 PM
evoxisking's Avatar
mistake not going with a gtx turbo
