Airtrek 2.4l + Mivec(evo 9) + AT + speed density + dbw + ...
Hi everyone. My name is Stanislav.
In this post I will describe the history of improvements to my car.
The car was purchased in 2013. Since 2014 I have been actively engaged in tuning my car.
Intake system * Modified intake manifold * Mazda RX-8 throttle body 80mm * AMS Intercooler * Custom intercooler piping
* Kinugawa td05-20g
* Tial BOV * Oil catch tank
Exhaust system * Doc race manifold
* Full 3” custom exhaust + adjustable valves
Drivetrain * 2200 RPM torque converter * Evo front LSD * Evo rear LSD * custom AT gearbox
Brakes * Evo X 4-pot 350mm front brakes * Evo 9 rear brakes
Etc * Carbing front and rear strut bar
History Initially, the car was with 2.0 4g63t + Evo manual transmission + garrett gtx3071.
But there was one unpleasant incident. And I thought about changing the config
Spoiler
A 4g64 was purchased to build 2.4 liters
Spoiler
Next, the process of preparing for the engine assembly. Building custom pistons. Purchase of parts, boring..
Before buying a evo head, of course, I thought about how the mivec solenoid control will occur. From the factory there were no automatic cars with such a head.
I made a controller that controls miveс and wiring for the solenoid and intake camshaft sensor.
Also a mini dash was developed for the stock instrument panel in this controller. Which communicates with the stock ECU via the DMA protocol and receives any data to display.
The controller calculates the current position of the intake camshaft based on signals from the CAS and Cam sensors. I also modified the ROM program for the functionality I need.
The target angle is taken from the standard ECU via DMA and rotates the intake camshaft by the desired number of degrees.
I also rewrote the calculation of air and transferred the car to speed density.
So I think it is the world first AT car on true speed density with mivec on stock ECU
Added pseudo random spark and fuel cut, like a Motec. Allows you to specify a seed that changes a pseudo random sequence of cuts. What ultimately affects the sound of launch control, rolling launch, and similar features
