Evo VIII MR Track Project From Australia
Old Oct 10, 2023, 06:43 AM
Jahtoot's Avatar
Wonderful and clean work. Thanks for sharing !
Old Oct 11, 2023, 05:32 PM
harry wilson's Avatar
Great work
Old Oct 12, 2023, 03:07 AM
benntrevv's Avatar
Weighed the car today and did a little bit of corner weighting, 1334.5kg with 1/2 a tank of fuel. Which I thought was pretty light.
Benny
rustykan (Oct 12, 2023)
Old Oct 12, 2023, 12:11 PM
thepoint4life23's Avatar
This is a really clean build. Thanks for sharing.
Love the Carbon manifold cover
Old Oct 14, 2023, 02:20 AM
benntrevv's Avatar
Originally Posted by Ayoustin
Solid! Looks like a very clean car!
Originally Posted by harry wilson
Great work
Originally Posted by thepoint4life23
This is a really clean build. Thanks for sharing. Love the Carbon manifold cover
Thanks everyone
Old Oct 20, 2023, 01:42 AM
benntrevv's Avatar
Few bits turned up today:
Infinite Evo Wet Sump Kit
Sparco P310 Steering Wheel
NRG Short Hub
Custom 125mm Steering Wheel Spacer
Just waiting for my 7L of motul 300v to turn up then I can go ahead on fitting the sump kit along with the tomei scraper kit.
Benny
codgi (Oct 20, 2023)
Old Oct 20, 2023, 02:05 AM
benntrevv's Avatar
I fitted the wheel, spacer and hub today. Went for the Sparco p310 wheel as I like the small flat design & it comes with 2 buttons. I’ll be using one for my horn as the car is still road legal, and the other will be to change the display page on the motec dash once it arrives and I get it installed. The buttons on the steering wheel are a really neat design as well, the wheel has a a recess milled into the back for the wires to sit in and then go through the middle of the spacer so it’s all kept hidden.
The spacer is a 125mm billet aluminium custom job by my friend, he works for the shell v-power v8 supercar race team so has use of all there equipment which has its benefits, it’s a quality bit of engineering.
Benny
The following 3 users liked this post by benntrevv:
codgi (Oct 20, 2023), Jahtoot (Oct 20, 2023), osetsky (Oct 23, 2023)
Old Oct 23, 2023, 01:46 AM
benntrevv's Avatar
Started to take bits off the car today ready for the infinite evo sump, tomei scraper kit & cold side intercooler piping to go on tomorrow. I jacked the car up on 4x axle stands and took off:
Front Wheels
Bumper
Undertray
Drained oil
Cold side piping
Turbo drain
Downpipe
Underside strut bars
Starter motor
All that’s left to take off tomorrow is the sump.
I took the new sump out, it’s recommended to clean it thoroughly as it’s got a lubricant on it for transportation to keep it nice and fresh, I filled it up with water and hosed it out just to make sure if there was any debris in there it came out. Tomorrow I’ll spray it all with brake cleaner and then blow dry it.
Benny
The following 4 users liked this post by benntrevv:
deylag (Nov 1, 2023), Jahtoot (Oct 23, 2023), osetsky (Oct 23, 2023), rustykan (Oct 23, 2023)
Old Oct 23, 2023, 10:17 AM
Jahtoot's Avatar
I've read up great things about that infinite wet sump on these forums. I hope to get it one day, totally worth !
Old Oct 31, 2023, 01:52 AM
benntrevv's Avatar
Finished installing the Tomei Scraper kit & the Infinite Evo sump. All in all it was a pretty easy job to do, the instructions that come with the sump kit are very useful and as long as they are followed, the install will go well.
Once installed I put the car back together and then had to set the oil pressure. I logged the oil pressure before I took the old sump off, it was 95psi when the motor was hot and revs being held at 5k. I just did the same with the car on axle stands so then I could get underneath and keep adjusting until it was at the same 95psi.
I’m back on track in a couple of days so at least I’ve got peace of mind that I’m not gonna have any major oil surge.
Benny
deylag (Nov 1, 2023), Jahtoot (Oct 31, 2023), osetsky (Oct 31, 2023)
Old Nov 9, 2023, 11:47 PM
benntrevv's Avatar
Motec dash rocked up this week so I got that fitted, my friend made me a mounting bracket using a 3d printer, it came out perfect.
At the moment it’s just a lap timer. I’ve ordered a Link G4X ecu so once that gets here I’ll get it on, get the car tuned and then I will be able to run all of the engine data off of it.
Benny
codgi (Nov 21, 2023)
Old Nov 9, 2023, 11:51 PM
benntrevv's Avatar
Picked up a used set of Nitron R3 Coilovers, there just under 2 years old. I’m having them sent to Nitron so they can refurbish & service them, also adjust the Valving and change the springs to suit my setup. I’m so excited to get these on and properly set up the car.
Benny
The following 2 users liked this post by benntrevv:
deylag (Nov 19, 2023), Jahtoot (Nov 10, 2023)
Old Nov 11, 2023, 12:05 AM
benntrevv's Avatar
Just ordered an Alcon 343mm Club Race kit which should rock up in mid December. I’ll be pairing this with some Project Mu Racing999 pads, so I should have some good braking performance!
Benny
deylag (Nov 19, 2023), Jahtoot (Nov 14, 2023)
Old Nov 14, 2023, 01:51 PM
Jahtoot's Avatar
Sexy Build man ! love the quality and simplicity.
benntrevv (Nov 15, 2023)
Old Nov 18, 2023, 01:59 AM
benntrevv's Avatar
Was back on track last week, car performed perfectly which I expected. I’ve got one more track day next week. And then that’ll be it for this year I think.
I’ll be getting the suspension back from Nitron in a few weeks and then the brake kit beginning of December so that will keep me busy.
Few pics from the track
Benny
The following 5 users liked this post by benntrevv:
black E (Nov 18, 2023), codgi (Nov 21, 2023), deylag (Nov 19, 2023), Jahtoot (Nov 20, 2023), osetsky (Nov 18, 2023)
Quick Reply: Evo VIII MR Track Project From Australia
