FS: BNIB Synapse Synchronic Diverter Valve
Hey Guys,
I have a BNIB Synapse Synchronic Diverter Valve (probably one of the best if not the best BOV/DV you can but for your car) that I recently purchased. Nothing is wrong with it and it was never used.
This is the exact same thing vendors are selling but it doesn't come with the boost line kit. You don't need the lines and can just use vacuum hoses and a y connector from any local auto store but if you do want it you can just contact Synapse and purchase one which should run around $15.
NEW PRICE: $210 Shipped...this is a steal compared to vendor pricing!
Information on the DV...
"Synchronic DV is the first, truly compact, zero-diaphragm, high-flow Diverter Valve with a blistering actuation time measured at 25 milliseconds. MAF and speed density applications can apply the new design in push or pull orientation with the ability to fully re-circulate or vent-to-atmosphere the valve’s discharge. Construction is based on near-net investment casting of aerospace-grade Aluminum for the body, followed by CNC machining of all components including the forged 6061 actuator assembly. A complete selection of available mounting flanges are interchangeable between the SB and DV series and users can either upgrade from an existing BOV/DV or weld on to a new project. Boost/vacuum connections are made via 1/8th NPT threaded bosses that accept either Boost Connect™ or included nickel-plated-brass barb fittings. Each assembly is pressure tested to withstand 60 psi and positive lock clamshell retainers are included with each assembly for fitment."
Not exactly sure but the DV is a lot smaller than the BOV so there is more room under the hood, it's all black so it helps with cops, has the ability to run push or pull type and I think its faster not exactly sure. But I know it is one of hte best BOV/DVs out on the market right now.
