F/S: (FL) Cams, Injectors, Clutch
Kelford 214-A Cams - $500 shipped - SOLD
Used for a couple thousand miles; New these go for around $600 - 650
RC 750CC Injectors - $200 shipped - SOLD
New these go for $350; compatible with stock ECU; used for a couple thousand miles
SOLD! ACT Clutch - TTP Spec
BNIB; never used; originally bought when I thought I had to replace my clutch; turned out to be a leaky seal in the tranny, so never needed it; Sells new for $565+
I am getting ready to sell my car so I am selling extra parts. I will post pics soon including close-ups of the cams so you can see they are authentic.
Kelford Specs
4B11 EVOX, Stage 1 camshafts to suit stock valve springs and stock turbo.
Approx RPM Range:
Duration @ 0.1mm Valve Lift: 264 Inlet/252 Exhaust
Duration @ 1.0mm Valve Lift: 224 Inlet/212 Exhaust
Valve Lift @ 1 to 1: 10.00mm Inlet/9.35mm Exhaust
Centerline @ Full Lift: Variable Inlet/Variable Exhaust
Kelford Specs
Approx RPM Range:
It's an HDSS - TTP Spec. The link below is the exact one.
http://ttp-engineering.com/catalog/s...tch-p-342.html
I am back home, so I will post pics tomorrow morning.
