FS: 12" hifonics sub, legacy amp, custom ported box
ABLE TO SHIP!
Hello, I have a slightly used Hifonics sub (bought brand new) and Legacy amp in a custom made ported box. Everything works fine, I just need the money for my car so this is going. The sub is 12" and single 4-ohm 300 watt RMS. The amp is a Legacy LA-490, 2 channel amp, which bridged it is 300 watts RMS x 1, but im sure you could hook up a 450 watt or even a 600 watt sub to it and it would still pound! The box was custom built for this specific subwoofer, with the specs from Hifonics themselves. It is 20" wide, 16" deep, 13.5" high, with a 4" wide, 20" deep port. It has been carpeted black, and is approximately 1.5 cu. ft., the optimum size for max SPL, again according to Hifonics. It also includes all wiring you will need to wire it up except the ground wire, but I can include the wire necessary, all you need are two terminals; a 4 gauge ring terminal, and a 4 gauge spade terminal. It comes with approx. 17' of 4 gauge power wire (Stinger), 17' RCAs (Stinger PRO Level 3), 17'+ remote wire (including terminals), and a 3-way, 4 gauge distribution block (Stinger) (I had 2 amps hooked up, but returned the other one). $130, PM if interested!
