CA: Brembo GT 4-wheel Big Brake Kit with Spares!
Why are you dead set on the 6-pot calipers?
Both the 4-piston and 6-piston calipers were available when I got these from Brembo, and I specifically picked the 4-piston brakes. The two calipers have the same effective brake torque, so there is no difference in brake performance.
The only difference is the pad -- the 6 piston has a bigger pad, but because it is so new it is also more expensive and you have much fewer pad options. The 4-piston is the same caliper used on Ferrari, Porsche, etc., and so you can get any pad you want. It's also much, much easier to swap pads on the 4-pot.
Just something to consider.
Do the 6-piston expel heat better since it is able to run a much bigger rotor?
Bump for you man!
Most people have no idea what they're buying.
We just outfitted our E36 M3 for the 25 Hours of Thunderhill. In discussions with Brembo, we _still_ went to the 4-piston.
The only advantage of the 6-pot is that the pad is 40% larger and so lasts a lot longer, but in order to change the pad you have to dismount the ENTIRE CALIPER. That's fine for a street car, but for a race or track car, I'd prefer simply popping out two pins (5 minute pad change?)
[QUOTE=peter*g;7402925]
UPDATE: *** I will consider trades --diffs/trans case/motor, or other chassis spares ***
Very tempting as I have a tranny, transfer case and complete rear end/suspension set-up I was going to mount in a different chassis and I know I will never get around to it.
