Clutch-Masters Disc CLUTCH
will it bolt onto an exedy pressure plate because i have a stage 2 with 4 puck ceramettalic, so can i just replace the 4 puck with this clutch? and also....is this 4 puck and what's the torque capacity on this?thnaks
The disc is a full face and here is some info :
High performance street system
· Holding capacity 70% over stock
· Sprung hub/cushioned disc
· Steel backed organic friction material
This clutch disc will mate (bolt) into the stock flywheel and pressure plate, I don't know about the EXEDY... if the EXEDY disc will bolt into the stock flywheel and pressure plate, then this will bolt into the EXEDY...!!!
Thanks for replying ...
100.00 shiped?
