Exedy Stage 2 Cerametallic Clutch Kit/Flywheel
Hello,
I have a Exedy Stage 2 4 Puck Cerametallic Clutch Kit and a Stock Flywheel and both have 3000 miles on them only. Plenty of life left, broke in for about 550 miles and flywheel has no cracks or high spots....can be resurfaced if you want to for cheap. I love this clutch....engages great, no problems with it what so ever, i just got a exedy hyper single, so I'm just going to sell this one.
EXEDY cerametallic clutches are designed to handle the abuse of high powered modified engines. Our cerametallic friction material can handle much more slippage than stock type disc assemblies without slipping and fading. All cerametallic discs feature spring center dampers to reduce impact and shock loads.
Retails at over $800 for the cluch kit and the stock flywheel retails at about $300, this combo is over $1000 worth...I'm selling the clutch kit for $400 and the flywheel for $150...but if purchased together, I will give you the combo for $500!
Reasonable offers will be considered also!!!
Thank you
Thank you
Nice clutch, I have the same one. It holds big power and the launching will be very good when coupled with the heavier stock flywheel. I would recommend this clutch to anyone who wants big holding power without sacrifice.
