fs. ultimate racing test pipe w/ cel fix
Old May 28, 2008 | 08:25 AM
Itchy's Avatar
get the most out of your engine and ditch the stock cat or your hfc for a full 3 inch non resonated test pipe with no taper.. decided to sell this because i went with a cutout and no purpose for this now..
for sale.. selling my ultimate racing test pipe with the mechanical fix that i made so that you will not get any check engine lights to come on.
price.. 75 shipped for everything
pm me if interested, will clean out the box right now
cash is always good but will accept paypal if planning on shipping
pics will be up later in the day
Old May 28, 2008 | 07:08 PM
Itchy's Avatar
bizzummpp
Old May 28, 2008 | 10:31 PM
Itchy's Avatar
bummpp
Old May 29, 2008 | 02:16 PM
Itchy's Avatar
afternoon bump
Old May 30, 2008 | 10:48 AM
Itchy's Avatar
pics up
Old May 30, 2008 | 11:00 AM
Nesiop's Avatar
Why do you have that plug in the test pipe? If you move your o2 sensor to that bung it does not throw a code.
Old May 30, 2008 | 11:26 AM
EvoBroMA's Avatar
yeah right, that was the whole selling point on the UR test pipe, the mechanical fix is built in. you just have to make sure its facing the right way.
Old May 30, 2008 | 11:36 PM
Itchy's Avatar
no the mechanical fix i made.. bout 10 dollars at autozone.. had to dremel the inside of the fouler for the o2 sensor to fit.. if you use without the extra piece, the o2 sensor is gunna pick up too much gas flow and therefore throw a code
Old May 31, 2008 | 07:10 AM
Nesiop's Avatar
That is incorrect.
UR did extensive testing and I know you only joined back in 05 but when they first started selling evo parts they were the company to be for that part. It does not throw a code. Other testpipes do and need that trick you mentioned but this does not. I've run that same test pipe in both my 03 and 05 evo's and with stock ecu and with the utec with no issues ever.
Old May 31, 2008 | 11:55 AM
Itchy's Avatar
ultimate racing had a older version of this test pipe which had an arm for the o2 sensor for it to run leaner which is what you may be thinking of ..but either way, i never got a code so i guess i did something right
