FS:Starter / OEM coil pack / stage 1 exedy clutch / MAF + Filter /Ingalls torque damp
Here is an OEM starter, about 100K miles on it, still worked when removed, make an offer.
Here are some OEM coil packs, same milage as above, worked great, used ngk 8s on them, never had trouble with them. Make an offer.
Here is a stage 1 Exedy racing clutch, has about 4K miles on it, still in GREAT condition. Make an Offer.
The ingalls torque damper i do not have pics of yet, it was only on the car for less then 200 miles. Thing works, shockingly enough, it improved my shifting and how quickly the car responded to throttle. You know on the Evo 8 when you have alot of torque in your car, your engine bends forward and your transmission will lock you out of gears? This thing fixed that problem. Well worth buying. i paid 170 + shipping for it, i'll take 100 shipped. Pictures will be up later.
Very interested in the Ingalls Engine Dampener. I almost bought it for $150 today, brand new.
Please PM or post pics with all the included hardware/ brackets.
Also, perhaps you can give me an input on an item.
Did you have any noise/rattles with the Exedy stage1 clutch, when you let off the gas at around 40-60mph on higher gears? Did you use a lighter flywheel?
I have this rattle together with some other guys on this forum. Thank you, Toshi
OK,so do you just use the stock nuts/studs (on the engine side) to mount it?
I guess I'm asking if everything that came with it new are pictured?
If so, I'll Paypal you the $100. Thanks.
