MAF-T Pro (MAF Translator) w/ speed density & boost control
Old Feb 17, 2010 | 05:00 PM
shunderwunder's Avatar
I'm selling a used MAF-T Pro with speed density setup & boost control. I used this for a little over a year & is in great condition. I cut the harnesses that go into the engine bay so that I could run them without having to find/make a hole large enough to run the connectors through. I did not splice them back together after removal due to the possibility that whoever buys this may need to do the same thing. Included is the MAF-T Pro control box with harness (to be spliced into ECU wiring), 3 port boost control solenoid & harness, speed density harness with 3bar GM MAP sensor, serial cable (connect to laptop), & instruction manual. You will also need a GM IAT sensor (Intake Air Temp). This can be found on the MAF-T Pro site for $17.00 The one I had was dammaged and will NOT be included. Any info about this product can be found on the MAF-T pro website here http://maftpro.com/tproinfo.shtml
I'm asking $300 shipped (continental US) for everything. This setup runs about $600 new. Let me know if you have any questions.
shunderwunder
Aug 6, 2008 10:50 PM
shunderwunder
16
Apr 3, 2008 08:18 PM
shunderwunder
Mar 11, 2008 05:55 PM
shunderwunder
Mar 8, 2008 07:30 AM
