AEM Tru-Boost installed
Old Mar 15, 2008 | 06:28 PM
shunderwunder's Avatar
I got my AEM Tru-Boost boost controller installed today & decided to post a few pics of the install since I haven't come across any when searching. I used a spare piece of metal strap to make a mounting bracket & mounted the solenoid to the xenon ballast. It took a little longer than I had expected, but didn't run into any major problems. I have not been able to set it up & test it yet because the car is torn down for other mods & repairs at this time.
Old Mar 15, 2008 | 06:35 PM
bevolucion's Avatar
not being a jerk or anything the installation looks good but I had bad experience with the same solenoid it went bad pretty quick. It went bad and I didn't want to believe it because it was so expensive and all, but it only lasted me about four months and everything was installed fine. Just keep an eye on that, just my 2c. I end up getting a manual boost controller.
Old Mar 15, 2008 | 06:42 PM
That's kinda crappy. I hope this lasts a little klonger than that. I mounted the solenoid to the bracket with 2 layers of double sided foam tape & secured it with zip ties. I'm hopeing this will lessen the vibration the solenoid sees. That may help, but I dont really know.
Old Mar 15, 2008 | 06:44 PM
bevolucion's Avatar
hopefully, good luck with it.
Old Aug 3, 2008 | 11:03 PM
EvoIXMR's Avatar
bringing this thread back from the thread - I am installing mine and I dunno which wire is power and which one is ground on the boost solenoid. Can someone help.
Thanks!
Old Aug 4, 2008 | 08:01 PM
X-T-C's Avatar
^ it dosent have polarity you can hook it up both ways
Old Aug 6, 2008 | 07:56 PM
bao's Avatar
bao
good. now can you post pics to show where you tapped power? im kinda stumped on where to tap 2 red wires.
Old Aug 6, 2008 | 10:50 PM
EvoIXMR's Avatar
Here is how I did it - I tapped all my power and ground off the ECU. I tapped a lead line into it 12V switched power and 12V ground. Thats how I hooked up all my gauges and zeitronix as well. Its a clean way of doing it, I think.
You can find ECU pinout on road race's site for VIII and IX
shunderwunder
Jan 16, 2016 03:15 PM
shunderwunder
16
Apr 3, 2008 08:18 PM
shunderwunder
Mar 11, 2008 05:55 PM
shunderwunder
Mar 8, 2008 07:30 AM
