Mark this thread as Sold
FS: Evo9 turbo, mivec solenoid, gear, valve cover and lots more!
Old Aug 17, 2012, 05:49 PM
OMEGA PHX's Avatar
Money sent for knock sensor please lmk my tracking info
OMEGA PHX is offline
Old Aug 18, 2012, 10:11 AM
Anarchy99's Avatar
What was the first name?
Anarchy99 is offline
Old Aug 19, 2012, 07:33 AM
OMEGA PHX's Avatar
Carlos, payment was sent on august 14, after our agreement through PM's
Old Aug 20, 2012, 10:03 AM
Anarchy99's Avatar
updated 8-20-12 - sold parts have been removed or pics deleted.
Originally Posted by anarchy99
from the few evo's i have had and the couple of racing engines i built, i have ended up with a lot of parts i no longer need. They have been sitting in plastic bins for a while now and finally got motivated enough to clean out the garage and see what i have left.
I guess i will just post up a picture and a price since i took a lot of pics and want the thread to be easy to find what you are looking for.
2006 evo 9 turbo w/ water and oil lines, inspected. Can come with wastegate also, just ask. As pictured $550
stock evo 8-9 intake manifold. Great core for porting or to go back to stock $110
mivec cam gear with or without camshaft $185
mivec solenoid for 2006 evo 9, works perfect $75
evo 8 oil cooler with lines and banjo fittings, banjo bolts $120
evo 8-9 oil pan. Costs $145 new at the dealer, first $65
evo 8-9 front case with oil pump (18k mi) i put a new one on my 2.4l
evo 8-9 rear main seal housing $15
evo 8-9 camgear side motor mount $22
evo 8-9 thermostat housing water neck $20
evo 8-9 5sp transmission mount $20
evo 8-9 exhaust manifold tapped for egt (can be plugged also) $80
evo 8-9 5spd oem transmission spacer $10
evo 8-9 stock throttle body (w/o tps and iac) $45
evo 8-9 serpentine belt auto tensioner $25
evo 8-9 rockers for valvetrain (set 16) $30
evo 8-9 oil filter housing $20
evo 8-9 oil squirters set with banjo bolts $15
evo 8-9 low oil light sending unit (these go bad frequently) $15
evo 8-9 stock rear motor mount $20
greddy oil filter housing sandwich adapter $20
evo 9 mivec oil feed line oem $8
evo 8-9 knock sensor $25
evo 8-9 stock fuel pump assembly with level float and top ring (no pump) $75
6 speed mr transmission motor mount. Price $20
alternator bracket to intake manifold $5ea
cam angle sensor for evo 8-9 $20
evo 8-9 stock crank pulley $45
evo 8-9 crank sprocket, crank bolt, washer and crank trigger wheel $12
evo 8-9 crank sensor and mounting plate $40
evo 8-9 dipstick tube and dipstick $8
evo 8-9 stock fuel rail $15
evo 8-9 stock fuel pressure regulator $20
dsm 440cc injectors (blue top) $75
i accept paypal. Thanks for looking
Old Aug 20, 2012, 11:16 AM
Honni414's Avatar
PM me a price for the tensioner pulley to 53227
Honni414 is offline
Old Aug 20, 2012, 12:42 PM
Anarchy99's Avatar
Private messages returned!
Old Aug 20, 2012, 06:21 PM
OMEGA PHX's Avatar
You haven't replied to any of my PM's, The knock sensor is still listed even when I already sent the payment for it a week ago and it should have already been shipped to me.
WHATS UP?
Old Aug 20, 2012, 07:14 PM
Anarchy99's Avatar
WHATS UP?
I have 3 knock sensors available. I am still out of town and will be back shortly. I have your P.O. BOX in PR and ship label ready, just waiting for my corporate office to send me home so I can send it out with this label I printed.
Old Aug 20, 2012, 07:19 PM
OMEGA PHX's Avatar
Ok, thanks for answering, I didn't know you were out of town. GLWS
Old Aug 21, 2012, 07:42 AM
Anarchy99's Avatar
Most up to date list of available parts left:
Originally Posted by Anarchy99
From the few Evo's I have had and the couple of racing engines I built, I have ended up with a lot of parts I no longer need. They have been sitting in plastic bins for a while now and finally got motivated enough to clean out the garage and see what I have left.
UPDATED 8-20-12 - SOLD PARTS HAVE BEEN REMOVED OR PICS DELETED.
I guess I will just post up a picture and a price since I took a lot of pics and want the thread to be easy to find what you are looking for.
2006 Evo 9 turbo w/ water and oil lines, inspected. Can come with wastegate also, just ask. As pictured $550
Stock Evo 8-9 intake manifold. Great core for porting or to go back to stock $110
MIVEC cam gear with or without camshaft $185
MIVEC solenoid for 2006 Evo 9, works perfect $75
Evo 8 oil cooler with lines and banjo fittings, banjo bolts $120
Evo 8-9 oil pan. Costs $145 new at the dealer, first $65
Evo 8-9 front case with oil pump (18k mi) I put a new one on my 2.4L
Evo 8-9 rear main seal housing $15
Evo 8-9 camgear side motor mount $22
Evo 8-9 thermostat housing water neck $20
Evo 8-9 5sp transmission mount $20
Evo 8-9 Exhaust manifold tapped for EGT (can be plugged also) $80
Evo 8-9 5spd oem transmission spacer $10
Evo 8-9 stock throttle body (w/o TPS and IAC) $45
Evo 8-9 Serpentine belt auto tensioner $25
Evo 8-9 rockers for valvetrain (set 16) $30
Evo 8-9 oil filter housing $20
Evo 8-9 Oil squirters set with banjo bolts $15
Evo 8-9 low oil light sending unit (these go bad frequently) $15
Evo 8-9 stock rear motor mount $20
GReddy oil filter housing sandwich adapter $20
Evo 9 MIVEC oil feed line OEM $8
Evo 8-9 knock sensor $25
Evo 8-9 Stock fuel pump assembly WITH LEVEL FLOAT and top ring (no pump) $75
6 speed MR transmission motor mount. Price $20
Alternator bracket to intake manifold $5ea
Cam angle sensor for Evo 8-9 $20
Evo 8-9 stock crank pulley $45
Evo 8-9 crank sprocket, crank bolt, washer and crank trigger wheel $12
Evo 8-9 crank sensor and mounting plate $40
Evo 8-9 dipstick tube and dipstick $8
Evo 8-9 stock fuel rail $15
Evo 8-9 Stock fuel pressure regulator $20
DSM 440cc injectors (blue top) $75
I accept paypal. Thanks for looking
Old Aug 22, 2012, 08:18 AM
Anarchy99's Avatar
Few things left. See below
Old Aug 22, 2012, 01:14 PM
Corbin09's Avatar
Do you have a TPS you might be able to part with?
Corbin09 is offline
Old Aug 22, 2012, 05:47 PM
Anarchy99's Avatar
The only one that I had available sold already, sorry
Old Aug 24, 2012, 07:28 AM
Anarchy99's Avatar
Payday bump lots of good stuff still for sale
Old Aug 27, 2012, 10:11 AM
Anarchy99's Avatar
ttt
Quick Reply: FS: Evo9 turbo, mivec solenoid, gear, valve cover and lots more!
