FS[Northeast]: built 2.0L short block, pistons, buschur intake,
Hey guys, money is getting tight so I'm going to have to sell some of my parts.
Complete 2.0 Short Block
Since people here on EvoM prefer to use their own trusted machinist, I am selling all of the parts you need, ready to be assembled. Simply drop the package I send you off at the shop and your good to go. Block has never been machined. Crank and bearings were in perfect shape.
$1500 + shipping and paypal
4g63 block + girdle
stock front case, rear seal, balance shafts, pickup tube, oil squirters, baffle, knock sensor (everything you'd find in a stock 4g63 minus stock pistons/rods)
oem 88mm crank
Eagle H beam rods with ARP 1000 rod bolts
CP lightweight aluminum pistons 9.0:1 .20 over (with all necessary rings and locks)
ARP Main studs
ACL Race Main bearings
ACL Race rod bearings
ACL thrust bearings
OEM front main seal
OEM rear main seal
+can include oil pan if needed
I previously had some bad luck with a buschur 2.3L that crankwalked. This is NOT that engine, this was pulled from my buddies running Evo 8.
Also have
Cobb Accessport with Cobb intake
ACT streetlight flywheel
stock rods
4g63 block + girdle
oem 88mm crank
ARP Main studs
ACL thrust bearings
OEM front main seal
OEM rear main seal
Also have
stock rods
