Spark tech coil on plug pro non cdi system | 1998-2006 evo 4-9
I have for sale a like new Spark Tech Coil on Plug PRO NON CDI System that I ran for about 3k miles before I upgraded to a CDI box. I paid over $700. Save a ton of money on a barely used unit. $500 OBO. Call, txt or email: 941-914-6614 or matthewlevonchristian at gmail. Item located in Sarasota, FL. Will ship at buyers expense.
This system features four Spark Tech spec high powered coils. This system will be a modification that you will feel. Expect a smoother idle, better drivability, increased torque, increased HP and a cleaner appearance compared to the factory coils. THIS ITEM IS APPLICABLE TO EVOs 4-9. Not applicable on JDM EVO MR models.
Features
Standard wrinkle black PRO NonCDI mounting plate.
100% plug and play (genuine oem connectors)
100% compatible with stock ecu & standalone ecu's
Tested to 954whp @ 0.020" plug gap
Military spec heat sleeve protector on wiring, rated to 428degF
Tefzel military spec wire, rated to 393degF
All components are brand new.
Out performs the DLI
Works well with stock turbo, larger turbos & fully built evos
Improve idle quality
Accelerates smoother through RPM range
Expect longer spark plug life due to a more efficient spark
Increased fuel economy (2-3mpg typically reported)
Due to increased spark energy you can run more boost without spark blow out
Improved throttle response
Decreased in cruise part throttle surge.
Smoother dyno curve.
