Enkei RPF1 17x9.5 on Evo (confirm this plz)
Old Jul 25, 2012 | 07:38 PM
  #31
PatNy's Avatar
Bump old tread looking to get these exact rims but wanna know what i need? front and rear rolled, rear pulled do i need spacers?
Old Jul 25, 2012 | 10:05 PM
  #32
killerpenguin21's Avatar
20mm spacers up front but no fender work. i did about 2k miles on the setup and never rubbed once in the rear, but because i track the car i rolled just to be careful.
my car is using gtworx springs and 255's.
Old Jul 25, 2012 | 10:23 PM
  #33
Construct's Avatar
With 17x9.5 RPFs, 245/40/17s, and 20mm spacers up front I had rubbing issues, but only under autocross conditions and only with a passenger. After flipping the camber bolts to the max camber position and massaging the fender liner with a heat gun, I had no rubbing issues with that setup.
Definitely won't fit without 20mm (or 18.5mm if you like to cut it close) spacers up front.
Old Jul 26, 2012 | 09:40 AM
  #34
i should have also mentioned im running 1.7 degrees camber up front due to a seized bolt and i believe 1.5 in the rear. still need to put more up front (2-2.1). i only rubbed in the front once when hitting a HUGE frost heave
Old Jul 26, 2012 | 10:42 AM
  #35
PatNy's Avatar
So u guys are running 20mm spacer up front with a roll and the rears just a roll and pull?
Old Jul 26, 2012 | 10:52 AM
  #36
Raptord's Avatar
I think with the +38 offset it's just 20mm spacer up front and roll in the rear to ensure no rubbing during hard driving/going over large bumps
Old Jul 26, 2012 | 11:38 AM
  #37
Boostd4's Avatar
Getting ready to put my 17x9.5 +18s on. Has a set of Hankook RS3s 255/40/17.
The guy I bought these from was running a very similar setup to mine (Swift w/MR Bilstein) and it fit with rolled rears and about 1.8-2.0 degrees in the rear.
I'm simply waiting to get the alignment done before I autox with them as I'm sure they will rub as it stands now. Good to see that people aren't having major issues with this setup.
Old Jul 26, 2012 | 11:41 AM
  #38
Raptord's Avatar
Please update us on your results. I'm considering the exact same wheel & tire combo for lapping/time attack.
Old Jul 26, 2012 | 11:43 AM
  #39
Boostd4's Avatar
Will do, will share pics and alignment settings as well.
The car these came off of did several track days at Thunder Hill with no issues...so I'm expecting it will be a turnkey setup. I already rolled and pulled the rear fenders, so the alignment should do it.
Old Jul 26, 2012 | 04:20 PM
  #40
right.
+18 in the rear will require fender neutering, well beyond just rolling.
Old Jul 27, 2012 | 06:57 AM
  #41
Construct's Avatar
right.
Exactly. +18 in the rear is a non-starter. Don't even think about it unless you hate your fenders.
But the 17x9.5 +38mm with 20mm spacers up front is a very common setup. Plenty of people have made it work. It will probably rub just a tiny bit if you try to it with the stock alignment, but with even a modest amount of camber dialed in it fits.
Old Jul 27, 2012 | 09:11 AM
  #42
Raptord's Avatar
Glad to hear. I'll be looking at 17x9.5 +38 with 20mm spacers in the front then.
Old Nov 21, 2012 | 10:49 AM
  #43
BradRoe's Avatar
i just put some 17x 9.5 +18 RPF1s on my IX with no spacers they looks fine car just needs to drop a little more
Old Nov 21, 2012 | 11:25 AM
  #44
Solenoid's Avatar
Veteran: Marine Corps
^^^Are you running the +18's in the rear as well?
Old Nov 23, 2012 | 03:28 PM
  #45
benihana242's Avatar
is the 17 x 9.5 the way to go? Does anyone have 17 x 9?
