Old Apr 10, 2017 | 08:02 PM
  #2011
truthdweller's Avatar
Veteran: Navy
Originally Posted by slc-ralliart
Yeah that is really strange. You almost have to assume something was messed up during the install since it didn't happen before the valves were done. I was just saying it is strange for valve float to just start happening out of nowhere.
Or something else was damaged or messed up during the timing belt insult. Meanwhile, my car sits in his yard without having been touched going on the second week.
Old May 23, 2017 | 06:26 PM
  #2012
Veteran: Navy
An AEM High Flow In-Tank Fuel Pump was installed with no change in symptoms...
I need my car back...I can't do this any longer, smh.
Old May 24, 2017 | 06:22 AM
  #2013
bakuro117's Avatar
Man this sucks... I wish I could come up and help you figure this thing out... :/
Old May 30, 2017 | 06:58 PM
  #2014
Veteran: Navy
Just picked it up from the shop today. Timing belt re-tightened, and AEM fuel pump installed. Nothing has changed...still with loss of power WOT @ 5000 rpm. Can't dump any more money into it like this so put it back in my garage.
Pulled out of the driveway to go fishing and car dies. I'm throwing a P0335 Crankshaft Position Sensor again. Was able to restart it and put it back in the garage. This is a recurring issue so I'm going to replace it once and for all...hope it solves the big picture as well.
Old Jun 4, 2017 | 02:02 PM
  #2015
Veteran: Navy
Picking up the crankshaft sensor tomorrow...towing the car to another shop to have them install it.
Old Jun 7, 2017 | 08:12 PM
  #2016
Veteran: Navy
Decided to take the risk of driving it to the shop and made it without incident. Picked up the car today, crankshaft sensor replaced...but no change, "darn it Jim!"...
Old Jun 7, 2017 | 08:20 PM
  #2017
Veteran: Navy
Something is going on mechanically...again, I'm pushing the dipstick out when I boost. I can't rev past 5500 rpms PERIOD! Whether I'm WOT or not, I can't get past 5500 rpms. It's as if it hits a limiter and won't progress. Wth happened? If I'm WOT, and it hits that "limit", the transmission won't upshift either... UNLESS I back off the throttle a bit, and THEN it'll shift, but I still can't get past 5500 rpms in the next higher gear.
Old Jun 8, 2017 | 07:24 AM
  #2018
RacerX-Ralliart's Avatar
hey not sure if you've tried it or checked yet but what if your pcv valve is stuck closed thus you're pressurizing the crank case putting stress on the internals? Not sure if it would cause the problem you're having, it sounds like something happened when they rebuilt your head... if you google search cheap cylinder heads there's a company based in Texas that sells rebuilt heads you just have to send them your head as a core. I got my replacement head from them and it looks badass. I've been slowly putting my car back together trying to remember where everything goes after two years. Hope you get this all figured out you're the original sport back AT turbo ralliart a role model for all
Old Jun 8, 2017 | 08:24 AM
  #2019
Resurrected RA's Avatar
Same here, it's amazing what I've forgotten in the year and half since my timing belt went and I pulled the head... Somehow, after taking great care to not lose any bolts, I can't find certain bolts...
Old Jun 8, 2017 | 10:32 AM
  #2020
Veteran: Navy
https://www.evolutionm.net/forums/04...l#post11721352
Old Jun 9, 2017 | 06:53 AM
  #2021
Veteran: Navy
Does your car have excessive oil consumption? Also does your crankcase/oil smell like gas? I had excessive blowby in my BMW that would push the dipstick out of the hole.
What was the cause of this blowby?
Old Jun 11, 2017 | 02:23 AM
  #2022
Veteran: Navy
Meanwhile, the P0133 O2 Sensor (B1 S1) popped back up. Going to replace this too, since it is reoccurring as well. Maybe this is the cause of my HORRIBLE gas mileage, and rich status when boosting.
Btw, I'm just made of money so, I'm good, no problem...
Old Jun 12, 2017 | 12:20 PM
  #2023
SilentCool's Avatar
This must be quite frustrating "Truth." Hopefully you make some head way soon and everything works out. As always keep us posted.
Old Jun 21, 2017 | 07:21 AM
  #2024
slc-ralliart's Avatar
I bored the engine my BMW .90 over from a 1.8 to 2.1 liter. The early BMW's (mine was an 82) did not have strong cylinder walls. My cylinder walls went egg shaped a few thousand miles after the engine rebuild causing excessive blow-by which created a lot of crank case pressure.
Old Jun 21, 2017 | 07:54 PM
  #2025
Veteran: Navy
Angel at Technica Motorworks has agreed to reopen my motor and recheck his work. He agrees that something may have been missed / reassembled incorrectly. I'll be bringing it in in about two weeks. Thank God.
