cam angle sensor plate position!
Old Jun 26, 2017 | 04:55 AM
babaz7's Avatar
yesterday my mechanic took off the cam angle sensor housing because it was leaking oil, he wanted to reseal it with RTV but when he took off the trigger plate he didnt mark the position where the trigger plate was...now it starts up and idles fine but as soon as i give it throttle to about 4000 rpms it missfires and sputters..
can anyone please tell me how do i reposition the cam sensor plate and which way should it be?
Old Jun 26, 2017 | 07:09 AM
babaz7's Avatar
I took these pics so its less confusing...the dowel pin is pointing up on the cams ..is this correct or should I rotate it?
Old Jun 26, 2017 | 07:51 AM
mines5's Avatar
Z-- Perhaps this might help you.
Old Jun 26, 2017 | 10:28 AM
babaz7's Avatar
thanks that helped alot, so according to the diagram, mine is 180 degrees off...will correct it tomorrow and see what happens.
btw i have a evo 8, it shouldnt matter right, its same for evo 8 and 9?
Old Jun 26, 2017 | 11:14 AM
mines5's Avatar
Never worked on a 9.
The key point is when you are working with mechanic who is less
Familiar with evo, always use service manual as a reference point.
There is a friend who also has a 2.1 destroker who might help you in future in khi.
Old Jun 26, 2017 | 07:00 PM
babaz7's Avatar
thanks..next time i will.
Old Jun 26, 2017 | 07:05 PM
babaz7's Avatar
Can anyone also tell me if the cam angle sensor is supposed to be dry or covered in oil when you take it out? Mine was covered in oil..
The cam sensor housing where the plate is was in oil too hence the leak but that should be dry right?
Old Jun 26, 2017 | 08:16 PM
4G63_EVO's Avatar
Should be oily yes
Old Jun 26, 2017 | 11:23 PM
mines5's Avatar
That's ok. Once you are done . Let it idle for 10 minutes . Notice any leaks. Take it out for a cruise and log.
Old Jun 26, 2017 | 11:30 PM
mines5's Avatar
Can you post a photo of your engine bay?
Old Jun 27, 2017 | 03:55 AM
babaz7's Avatar
yea sure..its a mess but
Old Jun 27, 2017 | 07:30 AM
mines5's Avatar
Back in the old days when she was a virgin.
First Love *
Old Jun 27, 2017 | 09:54 AM
babaz7's Avatar
yup, that must be years ago...
Old Jun 27, 2017 | 09:59 AM
babaz7's Avatar
Does anyone know if there should be a rubber seal or gasket on the cam sensor housing? Should there be a seal in the area which is in the picture? I put RTV sealant but its still leaking oil from bottom of the cam housing...
Old Jun 27, 2017 | 10:02 AM
mines5's Avatar
Zulfi-- that was back in 2008.
Did you install the sensor today?
