Evo X Electrical / Audio / Security Discuss electrical and audio system upgrades or alarm configurations.
Help identifying wire harness/wires
Old Aug 19, 2017 | 06:05 PM
X2jesse1x's Avatar
My radio hasn't worked since I got the car, so I've been trying everything I can think of to find the issue. I think I got it narrowed down to the amp, however while I was looking under the dash I noticed a semi melted wire harness and several cut wires. The harness is located on the drivers side firewall, under the dash, near the carpet.
Does anyone know what this harness is used for? I also noticed a spot that looks like it's for a harness, however this harness isn't long enough to plug into it.
Old Aug 19, 2017 | 06:35 PM
splattj's Avatar
Get the part number of that control unit. Based on your pics it definitely looks like it runs to it.
That melted connector gives me heartburn just seeing it.
Old Aug 19, 2017 | 06:52 PM
X2jesse1x's Avatar
I thought so to, however if you look at the black box. The wire harness connected to it is white and this one is thicker and black. I think it's to thick and won't plug into it. Plus the wires are far to short.
Old Nov 24, 2017 | 08:31 PM
tsx028's Avatar
Did you ever figure this out? I have the exact same harness/connector and I am not sure it plugs into it. Although my harness has a solid white part, not sure how it could connect.
Old Nov 24, 2017 | 09:10 PM
X2jesse1x's Avatar
No I have not. The only thing I can figure is that the harness is for something to do with an MR and is unused on the GSR. It appears that wires were cut from it. My guess is that one of the previous owners tried to tap into a wire on the harness and melted the dang thing and then cut the wires. But that's just a guess.
the harness doesn't have enough slack to go up to the module. I also have no cel lights on for anything.
Old Nov 24, 2017 | 09:22 PM
RazorLab's Avatar
FYI, that last photo is the ACD/AYC unit and is missing a connection.
Old Nov 25, 2017 | 05:06 AM
X2jesse1x's Avatar
hmm If that's the case, why don't I have a CEL?
could someone please take a picture of this area under their car so I can compare?
Old Nov 25, 2017 | 08:42 AM
X2jesse1x's Avatar
yes after looking at it, it's definitely the acd/ayc unit. But that harness plug is not the correct shape or length to plug into the empty spot
gobigny
Apr 16, 2014 10:09 AM
Senvae
Dec 22, 2013 12:25 PM
prowakeskater
Jun 5, 2011 06:31 PM
tboboy
Apr 26, 2010 11:50 AM
dorian7
Dec 4, 2008 03:55 PM
