Fuel Pressure: Please Help!
Old Jul 22, 2007 | 11:10 AM
kungfugirl's Avatar
pic up that should help u install ur gauge
Old Jul 22, 2007 | 03:31 PM
senate6268's Avatar
You have your fuel pressure sender in the wrong spot. Fuel pressure is only built before the regulator on the rail. After the regulator the pressure drops substantially as it returns to the tank. Splice into the fuel feed line before it hits the rail. Easy mistake.
Old Jul 22, 2007 | 10:06 PM
kungfugirl's Avatar
AH! senate! U BE THE MAN!!!!
Old Jul 23, 2007 | 08:58 AM
lancerrally45's Avatar
so how did you re-do it?
Old Jul 23, 2007 | 03:20 PM
kungfugirl's Avatar
working on it today. It goes on the other side of the rail.
Old Jul 23, 2007 | 08:38 PM
aaaahhhhhh. thanks for the info! pics? just to confrim
Old Jul 26, 2007 | 04:38 PM
smalltown's Avatar
bump on the picture for this. I want to see how it's done.
Old Jul 29, 2007 | 12:55 AM
kungfugirl's Avatar
picture up tommorow.
Old Jul 29, 2007 | 07:41 PM
pics? i got my egt, and boost hooked up, just need to make sure where that goes in and wut fittings
Old Jul 31, 2007 | 08:25 AM
bump for pics
Old Jul 31, 2007 | 10:12 AM
senate6268's Avatar
You could go to Home Depot and get a 3/8" T-fitting, two 3/8" barb fittings and a 3/8" to 1/8" reducer and there you go. Or you can get this:
Fuel pressure gauge adapter
All you do is cut the rubber fuel line that goes into the fuel rail and tee into it for a reading. You can mount a 1/8" fuel pressure gauge right there or mount your 1/8" fuel pressure sender there that will feed the reading to your fuel pressure gauge.
Old Jul 31, 2007 | 08:22 PM
what side of the fuel rail. pretty sure the driver side. ?
Old Jul 31, 2007 | 08:56 PM
senate6268's Avatar
Yes I'm sure. I've had a fuel pressure sender for the last year on my fuel line.
Old Jul 31, 2007 | 09:00 PM
awesome. thanks senate
Old Jul 31, 2007 | 09:07 PM
senate6268's Avatar
I borrowed a picture from your turbo install. Here you go!
Attached Thumbnails Fuel Pressure: Please Help!-fuel-pressure-pic.jpg
