Let's see your fully tuned timing maps
Old Nov 19, 2007, 08:35 PM
recompile's Avatar
OK,
I'm re-tuning soon, and I want to see how far off I am from a "very good" tune. I'm particularly interested in tunes that have shown strong dyno powerbands and/or good quarter mile trap speeds.
So please, post your timing map!
I'll start with mine that I'm running as of today (this is straight 93, I run 25psi, with a taper to 20 at redline... still on stock turbo, stock WGA, stock mani/O2. The Green in my sig is "on order", and wga, ported mani/hotside/o2 are going in a the same time):
Erickcolt (Sep 30, 2021)
Old Nov 19, 2007, 09:45 PM
Inprogress's Avatar
I hope I'm not out of line when I say, damn thats a lot of peak timing, is that 14* peak? And at 25psi, must make for a fun drive...
Old Nov 20, 2007, 12:28 AM
RazorLab's Avatar
100 oct. Mods in sig.
Power chart:
Old Nov 20, 2007, 01:34 AM
al\lupo's Avatar
Originally Posted by ShamelessCookie
OK,
How did you work on timing map #2 and #3?
Old Nov 20, 2007, 04:43 AM
recompile's Avatar
They are identical to #1
Old Nov 20, 2007, 04:45 AM
C6C6CH3vo's Avatar
Razorlab, have AFR for that hex or dyno?
Old Nov 20, 2007, 07:56 AM
dudical26's Avatar
This is for 93 oct and 25psi spike holding 20-21 to redline.
(note - I changed the scaling on both axis so be aware)
Old Nov 20, 2007, 08:23 AM
20psiMR's Avatar
100oct, just a 25psi spike but settles to 20. Dyno sheet in sig pic thread.
Old Nov 20, 2007, 08:43 AM
merkzu's Avatar
Here's mine. Tuned on E78 fuel at 28 psi with buschur intake, ams fmic, gsc s1 cams, 3" tbe, walbro 255, 1000cc injectors and gm bcs
drakart1z (Feb 17, 2024)
Old Nov 20, 2007, 08:56 AM
recompile's Avatar
dudical, I assume that square of 4-5° is for the two step? What benefit does that give you ?
Old Nov 20, 2007, 09:01 AM
dudical26's Avatar
12psi off the two step instead of 6-7 like stock.
Old Nov 20, 2007, 10:29 AM
matt55's Avatar
So what kind of loads are you hitting @ peak and 7.5k ? Something like 280 falling to 220 ?
Mahmoud Evo (Mar 17, 2020)
Old Nov 20, 2007, 11:00 AM
C6C6CH3vo's Avatar
Dont have any dyno charts yet, but last year when my 4K - 6K rpm (3rd) times were 0.3 seconds slower it was 305/304 on a MustangDyno and about 5 psi less with a ****** tune without WB. I won't guess my current #'s until I go again
Old Nov 20, 2007, 11:04 AM
dudical26's Avatar
That is exactly correct.
Old Nov 20, 2007, 11:58 AM
RazorLab's Avatar
Quick Reply: Let's see your fully tuned timing maps
