[FS] Ralliart to Evo X Turbo Swap Parts (RA Owner's dream list)
Old Jan 1, 2016, 01:39 PM
w8less1der's Avatar
Updates:
10/25/16: Added more items to this original post with pricing. The pictures are posted later in this thread.
10/18/16: Added more items to this original post with pricing. The pictures are posted later in this thread.
10/4/16: I am going to add quite a few more brand new and used Evo X parts to this thread in about two weeks so stay posted (intercooler, intercooler piping, BOV, boost control solenoid, HFC, airbox, crash beam, carbon fiber, bumper covers, and more). Have to take pictures of them with my screen name before I can post them.
Here is the first of many items (still available):
Brand New Cobb Boost Control Solenoid for Evo X and Ralliart (Part: 752750) - SOLD
2014 Evo X BOV with less than 2500 miles on it: SOLD
2013 Evo X OEM fuel injectors with less than 10K miles on them: SOLD
Used once Tactrix Open Port 2.0: SOLD
Less than 10,000 miles on the following:
Evo X intercooler
Evo X upper intercooler piping
Evo X lower intercooler piping
[B]Evo X diverter valve hose
Price: SOLD everything
New Evo X OEM front license plate bracket. Took out of wrapping for pictures.
Includes installation instructions and mounting hardware. - SOLD
Used Evo X Airbox, air filter, and intake tube - SOLD
New Dayco D length 71967 hose for installing the Evo X intercooler etc. on a Ralliart - SOLD
Evo X turbo inlet (see picture of it with airbox to make sure this is the correct name)
Includes gasket and two bolts - SOLD
New Mil.Spec (mil-spec.org) Three Evo 3" gaskets + nuts and bolts & 02 bung - SOLD
Used Mil.Spec (mil-spec.org) Evo X 100 Cell Bolt-On Cat aka high flow cat / mid pipe (less than 1200 miles on it)
Includes some bolts and nuts, O2 bung plug, but no gaskets - SOLD
OEM Ralliart front brake pads with less than 16,000 miles on them - $20 shipped
New OEM Ralliart rear brake pads MZ690187 - $25 shipped
New Mitsubishi OEM SST Transmission Filter (Evo X / Ralliart) Part # 2513A040 - SOLD
New DeatschWerks Fuel Pump Install Kit Part # DET 9-1009 - $Free with purchase of another item
New Mitsubishi Relays MR400709 (MFI relay) and MR122409 (fuel pump relay) - $15 shipped
Used Evo X turbo outlet elbow (I think that is what it is called. See pictures) - SOLD
Original listing:
New Year, so I am thinking about a new project. I slowly purchased these parts over the course of last year. I planned to swap two Ralliarts but my plans have changed so I am going to get rid of about half of the parts. I will keep updating this list as I have time because there are tons of part numbers. Before I ship items to you I will confirm via a private message the quantities and part #s of what you are buying.
The short version of this post is:
The required OEM parts, the recommended parts, and additional parts listed in this thread are included in this sale:
https://www.evolutionm.net/forums/09...arts-list.html
The hot side of the turbo, exhaust manifold, O2 housing, and stock down pipe were all professionally ceramic coated in 2015. None of these parts were used after the ceramic coating was performed.
- Turbo was from a 2013 Evo X with less than 21K miles - I took pictures of the fins so you can see their condition. Normal wear for the mileage. The turbo still needs to be put back together prior to shipment. I recommend that you perform any recommended maintenance to it prior to installing it. I also have the stock heat shields that were removed from them. The only bolts I think I am missing for them are the ones to attach the O2 housing's heat shield. I had a stud stick in one of the holes on the hot side when I removed it prior to ceramic coating. The threads were slightly bent so I ran a tap through the hole and then tested it with a brand new OEM turbo bolt to make sure the threads were fine.
Price: SOLD shipped for the full turbo (hot side and cold side etc.)
- The exhaust manifold, O2 housing, and down pipe have less than 27K miles on them (still available)
- Ceramic coated Evo X exhaust manifold - SOLD
- Ceramic coated Evo X O2 housing (comes with stock heat shield but they need to be mounted/welded on)
- Ceramic coated Evo X down pipe (comes with stock heat shield but they need to be mounted/welded on)
$150 shipped for both
- The supplemental parts are brand new and a combination of the MAPerformance Ralliart to Evo X Turbo Swap Kit and parts that I bought from the Mitsubishi dealership. For an easy install and removal I opted to buy turbo bolts instead of studs which is why you will notice there aren't studs in the list. You will need an additional nut to attach the turbo the exhaust manifold because for some reason I only ordered three. There are some spare parts also. Here are the parts (2/12/17: The ones that do not have SOLD next to them are still available):
QTY Part # Description
1 1555A417 Gasket, Exhaust Manifold to Head - SOLD
1 1515A184 Gasket, Exhaust Manifold to T/C - SOLD
10 MR187848 Washer, Exhaust Manifold to T/C
6 MN119783 Bolt, Exhaust Manifold to T/C
3 MD132930 Nut, Exhaust Manifold to T/C
1 1515A053 Inlet elbow gasket - This is already on the turbo/also have a brand new one - SOLD
3 MF911336 Bolt, Air Inlet fitting
1 MR281085 Gasket, Air Outlet Fitting - Used one was on air outlet/also have a brand new one - SOLD
2 MF911336 Bolt, Air Outlet Fitting
1 MR224441 Stud, Exhaust Outlet to T/C
1 MD132930 Nut, Exhaust Outlet to T/C
5 MD132933 Washer, Exhaust Outlet to T/C
4 MN119783 Bolt, Exhaust Outlet to T/C
1 MD194403 Gasket, T/C Oil Return Tube - SOLD
1 1310A344 O-Ring, T/C Oil Return Tube
3 MF241225 Bolt, Oil Return Tube (2 Upper, 1 Lower)
1 1555A320 Braclet, TC Exhaust Outlet ("O2 Housing") Bracket - SOLD
1 1515A156* Bolt, Exhaust Outlet Bracket
1 MR385722 Washer, Exhaust Outlet Bracket
1 1515A155 Bracket, T/C (Lower)
1 1515A156 Bolt, Lower T/C Bracket - SOLD
1 MR385722 Washer, Lower T/C Bracket
1 1515A166 Bracket, Compressor*Housing
1 MF140264* Bolt, Compressor Housing - SOLD
1 MF140260 Bolt, Compressor Housing*Bracket (T/C Side) - SOLD
4 1822A021 Spark Plugs (Evo X)
2/10/16: I apologize for the confusion. The following parts are also included:
The following parts are used, but listed here to keep the turbo swap kit parts together:
1515A150 Air Outlet Tube - $40 - SOLD
1555A423 Exhaust Outlet (“O2 Housing”) Ceramic coated - still available - price listed above
The following parts are part of the new MAP kit (Still available):
1555A289 Gasket, Exhaust Outlet to T/C - SOLD
1225A155 Turbo Oil Feed Tube
1 x MF650102 Banjo Bolt, Turbo Oil Feed Tube (Head Side) - SOLD
2 x 1226A003 Gasket, Turbo Oil Feed Tube (Head Side) - SOLD
1 x MF650013 Banjo Bolt, Turbo Oil Feed Tube (Turbo Side) - SOLD
2 x MF660064 Gasket, Oil Feed Tube (Turbo Side) - SOLD
1225A181 T/C Oil Return Tube
1310A577 T/C Water Feed Pipe
1310A469 T/C Water Return Pipe
4 x MF660065 Gasket, T/C Water Line (Feed and Return Pipes) - SOLD
2 x MF650114 Eyebolt, T/C Cooling Water Line (Feed and Return Pipes) - SOLD
Additional parts for getting ready for E85:
- Used Fuel Injector Clinic 900cc injectors with less than 5000 miles on them. Come with used pigtail harnesses and a set of new plug n play harnesses - SOLD
- Used DW65c fuel pump with less than 500 miles - SOLD
- New DW65c fuel pump install kit - SOLD
- New Deatschwerks Fuel Pump Hardwire Kit - $20 shipped
- Zeitronix Flex Fuel Sensor - SOLD
Give me 24 hours to respond to PMs and questions - I will respond to you regardless of your question.
Attached Thumbnails Ralliart to Evo X Turbo Swap Parts (RA Owner's dream list)-0101161257.jpg   Ralliart to Evo X Turbo Swap Parts (RA Owner's dream list)-0101161257a.jpg   Ralliart to Evo X Turbo Swap Parts (RA Owner's dream list)-0101161258.jpg   Ralliart to Evo X Turbo Swap Parts (RA Owner's dream list)-0101161258a.jpg   Ralliart to Evo X Turbo Swap Parts (RA Owner's dream list)-0101161325good.jpg
Ralliart to Evo X Turbo Swap Parts (RA Owner's dream list)-0101161326cgood.jpg   Ralliart to Evo X Turbo Swap Parts (RA Owner's dream list)-0101161318good.jpg   Ralliart to Evo X Turbo Swap Parts (RA Owner's dream list)-withzeitronix.jpg
w8less1der is offline
Old Jan 8, 2016, 10:48 AM
DfunctionEvo's Avatar
Part out possible? Looking at the fic 900's and dw65.
DfunctionEvo is offline
Old Jan 9, 2016, 12:44 PM
Payment sent for fic 900's, dw65c, install kit as well! Sold to me
Old Jan 9, 2016, 10:40 PM
w8less1der's Avatar
The following were SOLD!
Old Jan 24, 2016, 03:06 AM
w8less1der's Avatar
Bump
Old Feb 7, 2016, 08:17 AM
w8less1der's Avatar
Added a price for the full turbo to the original listing.
Old Feb 9, 2016, 03:53 PM
Mivec20's Avatar
Pm'd
Mivec20 is offline
Old Feb 14, 2016, 11:24 PM
SUX2BU85's Avatar
Hello,
I would like the exhaust manifold. Would you do $150.?
SUX2BU85 is offline
Old Mar 2, 2016, 07:01 AM
w8less1der's Avatar
Bump
Old Mar 17, 2016, 06:48 AM
w8less1der's Avatar
Bump
Old Mar 31, 2016, 06:29 AM
w8less1der's Avatar
Make offers. Keep in mind what it costs to ceramic coat these parts.
Old Apr 13, 2016, 08:52 PM
w8less1der's Avatar
Bump
Old Apr 27, 2016, 06:58 AM
w8less1der's Avatar
Bump
Old May 8, 2016, 09:33 AM
w8less1der's Avatar
Make offers
Old May 11, 2016, 06:02 AM
w8less1der's Avatar
Price dropped to $ shipped to the US 48 for everything left
Quick Reply: [FS] Ralliart to Evo X Turbo Swap Parts (RA Owner's dream list)
