Evo 9 problems
Evo 9 problems
Hi guys I joined the forum and been researching the problem I am having with my Evo 9 SE. It is stock other than a exhaust, intake, HBC boost controller. 63,000 miles
Problem 1: my evo 9 will smoke at idle and when I move it can see smoke blowing out from the exhaust. I replaced the PCV valve but it did not see to fix the problem. I checked the charge pipe and found little drops of oil. I also found drops of oil on the turbo on the intake side of the turbo also. Since my last oil change, I've put 1,200 miles on it and the oil on the dipstick is on the bottom notch line. Not sure if its normal to lose this much oil after 1,200 miles.
Problem 2: my car will idle at 10 HG vacuum and will idle lean from 17 to 20 afr. when I drive the car it seem to be driving fine cruising with 14.6 to 14.8 afr. sometime it will seem to sputter and the Afr will lean out 17 to 18 afr crusing when not in boost. I have pics and videos I will upload from my phone.
I never had any issues with this car before. I haven't done any mods when I bought this car a year ago. I noticed I may have boost leak as well.
It ran good when I bought the car a year ago from a dealership. so maybe the previous owner got it tuned. if I posted in the wrong forum please move this thread to right section.
Welcome.
The lean seems okay during idle and off boost. Mine will idle at 14.5-15 at idle. If I leave it in gear and let off gas, it goes to 20 as engine is getting dragged.
Oil in turbo is probably coming from valve cover from blow-by. You will need a catch can to filter that. What I do to check my fuel tune is pump my gas pedal down to see if afr goes to 11. Mine will drop to 10. If it stays over 12, you should get a retune.
Also, take off your intercooler and drain the oil.
MinusPrevious (Jun 25, 2017)
If you think you have post leaks, those need to be fixed before anything. Smoke, and the oil in the turbo is either crankcase pressure or an issue with the turbo. When the car has cooled off, grab the compressor nut and move the compressor up and down to check for excessive shaft play. Also pull it in and out. It should only move up and down a smidge, and in/out play should only be a few thousandths.
Welcome.
It never sounded lopey and from what the dealership told me, only mod it has was the exhaust, hbc manual boost controller. It sounded perfect before it idled lean. It sounds lopey from being lean I think. And my vacuum would be at 18hg before the problem.
Any chance bad turbo seal would cause a vacuum leak? And one time I drove it I noticed my car made boost up to 25lbs and I let off. My boost is set to 18lbs. Not sure where the boost leak would come from if it is a boost leak problem? I have a stock turbo with a internal wastegate.
