Will 9 lugs fit a X?
Old Nov 22, 2017, 09:50 AM
Tarry Harper's Avatar
I'm shopping for extended lugs for my X and want to go with arp but I'm only finding them for pre-X models. The lugs are the same are they not?
Old Nov 22, 2017, 11:00 AM
Received 1,544 Likes on 1,323 Posts
The ARP studs for 8/9 also fit the X.
Old Nov 22, 2017, 11:06 AM
That is what I thought but I figured I would ask just to be on the safe side. Thanks!
Old Nov 22, 2017, 11:47 AM
six40's Avatar
ARP 100-7717 is what I have for extended studs.
Old Nov 28, 2017, 05:40 PM
I appreciate the info but now I have another question...
...I picked up a set of STM 20mm spacers, arp extended lugs, and a set of open end lug nuts. My question is, do I need hub centric rings as well? If so, is it a one size fits all ring like a set of 73mm x 67.1mm fit any aftermarket wheel to fill the gap?
Old Nov 29, 2017, 05:35 AM
six40's Avatar
You don't NEED the rings but it is good to have. And generally no they're not one size fits all. They make a variety of adapter size rings depending on car center bore and wheel center bore. So in your case you have the measurements already by the sounds of it, just order some up. They're usually plastic, and pretty cheap.
Old Nov 29, 2017, 02:29 PM
Need to check your wheel. For example, some enkei's are 72.6mm cb.
RallyartRob
For Sale - Wheels / Tires / Suspension / Brakes
20
Feb 8, 2014 08:12 PM
dragon831
Sep 27, 2009 08:11 AM
Kami Speed
Evo 'For Sale' Wheels / Tires
Aug 25, 2009 01:32 PM
SoFlaBBY
12
Jul 22, 2006 10:14 PM
eericcc2
Sep 25, 2004 02:30 PM
Quick Reply: Will 9 lugs fit a X?
