Double pumper!
Old Dec 7, 2017, 02:06 PM
Nelson Ninham's Avatar
Double pumper!
Will I need a double pumper for my 2150cc injectors some day yes some day no I have a 450 right now!
Old Dec 7, 2017, 02:30 PM
Klaiceps's Avatar
Horsepower goal will dictate what you need.
Old Dec 7, 2017, 03:29 PM
heel2toe's Avatar
The reason you're getting conflicting answers is because there are other variables that need to be considered such as fuel type (e85) requires about 30% more volume vs pump gas. Also, what are your power goals? How much boost are you looking to run? Do you have any other fueling modifications in regards to the lines or FPR?
Without knowing any of the other information your question will remain unanswered.
Old Dec 7, 2017, 03:49 PM
38 psi e85 Gt35r ballbbearing and aeromotive fpr
Old Dec 7, 2017, 03:51 PM
Already at 32 34 but duty cycle is 90 to 100 at 38 psi
Old Dec 7, 2017, 04:43 PM
hutch959's Avatar
i would say yes...
but what is your fuel pressure at the rail?
Old Dec 7, 2017, 05:56 PM
4b11slayer's Avatar
32 psi of boost and 38 psi of fuel?
If so you are below factory base fuel pressure.
Base pressure is 43.5 .
You can raise your base pressure to give you injector duty cycle.
Old Dec 8, 2017, 06:10 AM
43.5 base at idle and trying continually to push 38lbs. Of boost
Old Dec 8, 2017, 06:52 AM
4b11slayer's Avatar
Have you raised base pressure see if injector duty goes down?
Old Dec 8, 2017, 08:01 AM
You need a double pumper. The Walbro 450 maxes out around 650whp. Your 35r is capable of more than that.
Old Dec 8, 2017, 11:59 AM
Okie dokie! People are telling me the efficiency of my turbo is 38psi. Should I go more or what’s personal opinions?
Old Dec 8, 2017, 12:17 PM
Boost is simply a measurement of restriction. 38psi is just a number. You can run a stock turbo at 38psi on the hit. You need to tune the car where its happy. There isn't a set boost number for a given turbo. Your whole setup plays a major role in how much power it will make with how much boost. Depending on which compressor you have. somewhere in the 725-800whp range is likely where you'll find the limit.
Old Dec 8, 2017, 12:18 PM
ronaldo9's Avatar
You can find the compressor maps of your turbo to know where the efficiency of the turbo lies based on your displacement. You have plenty of injector for your power goals, but I'd say you have have a fuel delivery problem, (lines, pump, pressure, etc.)
Old Dec 8, 2017, 12:24 PM
butte's Avatar
Just a quick aside, is that with the 450 rewire?
Old Dec 8, 2017, 04:35 PM
ronaldo9's Avatar
Yes
Quick Reply: Double pumper!
