2.4LR Evo 9 93oct Virtual Dyno Results
Old Feb 26, 2018, 02:33 PM
ConEvo's Avatar
Hello everyone, this is my first post in the forum and also my first thread. I would like some advice and thoughts about my current build. The build is as follows:
Engine
2.4LR Block
Carrilo 156mm H-Beam Rods
Wiseco 1400HD 86.5mm Pistons
Manley 100mm Billet Crankshaft
GSC Race Balance Shaft
Fluidampr Crank Pulley
ΟΕΜ intake manifold
ΟΕΜ throttle body
ΟΕΜ manifold
Evo 8 turbo with 20G compressor & 10.5 Hotside
Forge Evo 9 IWG with 18psi spring
Tomei V2 Downpipe
De-cat Test Pipe
HKS Hi-Power Silent Exhaust
Greddy intercooler
Mishimoto Intercooler Pipe Kit
ARP 2000 Head Studs
ARP Main Studs
ARP Balancer Bolt
Head
Mild Intake & Exhaust Porting
GSC R2 Cams
GSC spring & Retainer Kit
GSC Zero Tick Lifters
Supertech STD size valves
HKS Cam Pulley
ER Mivec Gear Mod
ARP Cam Tower Bolts
ARP Cam Bolts
Transmission
5speed trans from Evo 6 - Rebuild with Synchrotech carbon synchros
ORC Twin Clutch
4.11 Final Drive
ECU
Link G4+
Fuel
AEM 320 Fuel Pump
AMS Fuel Rail
ID 1050x injectors
93oct
Handling
Tein Flex Z
Project mu 2 piece SCR-Pro front rotors and HC+ pads with teflon brake lines
Wheels
OEM for now wearing Continental contact 3. Upgrading to Advan RS 17x8.5 wearing 245/40/17 Michelin Pilot Sport 4.
The run was done in 3rd Gear, 93oct pump gas. The boost was 25psi and uptop dropping to 20psi probably due to backpressure issues. I also attach the csv file of the log.
Next step after the purchase of Magnus V5 and S90 TB, is the purchase of a T4 1.15a/r 6466 TS with a T4 TS Manifold and twin mvs 38mm wastegates. After these, I will try to hit my goal which is around 600+whp or even 650+ on pump gas. Before you ask me why I use pump gas, E85 is unavailable at my country and race gas is not in my thoughts at the moment as it is a DD. However, here we use 98oct RON pump gas which i think it is a high quality 93pump gas in us
Thank you
File Type: csv
Old Feb 26, 2018, 05:36 PM
hutch959's Avatar
i notice you had 4.11 final. you did correct your VD data for it .. correct?
Old Feb 26, 2018, 06:09 PM
ExViTermini's Avatar
Needs more wgate preload. tq is delayed badly.
Wicked_X (Sep 19, 2019)
Old Feb 26, 2018, 06:26 PM
kaj
kaj's Avatar
why are you not seeing full boost until almost 5k RPM?
Old Feb 27, 2018, 12:04 AM
ConEvo's Avatar
Yes, i corrected it
Old Feb 27, 2018, 12:05 AM
ConEvo's Avatar
That is what i noticed too. The wastegate is a Forge IWG with a 18psi spring
Old Feb 27, 2018, 12:09 AM
ConEvo's Avatar
I do not know what is wrong with boost. I attached the csv log file. i did not manage to set up virtual dyno to show psi correctly. I maybe doing something wrong with the log recording
Old Feb 27, 2018, 12:12 AM
ConEvo's Avatar
Keep in mind that the tuning was done on the street and not on dyno. I do not know if on dyno the tuner can set it up to spool earlier
Old Feb 27, 2018, 04:45 AM
Tuxevo's Avatar
Something isn't right. A 20g on a 2.4 should see peak boost much, much sooner.
Old Feb 27, 2018, 05:45 AM
ConEvo's Avatar
I know. I will have a look to my wastegate preload and also on my 10.5 hotside for possible leaks
Old Feb 27, 2018, 02:28 PM
kaj
kaj's Avatar
I'm not too familiar with a 20g, but my FP HTA71 reached 20psi by 3400RPM or so and my FP Green did so around 3600RPM, both on a stock 2.0L. You're not seeing it until 4300RPM. Could be a number of reasons, but I'd do a boost leak test just in case, so you don't kill the turbo.
ConEvo (Feb 27, 2018)
Old Mar 4, 2018, 10:36 AM
ConEvo's Avatar
Update.
This weekend I tried to adjust the wastegate preload. the preload was far too stiff. Maybe 6 full turns. I adjusted it to 3 full turns and took it for a road test. It seems that it had slightly better spool but nowhere near from what is supposed to spool. Probably the hotside must have cracks. Here's the new log
Regards
Old Mar 4, 2018, 11:31 AM
CurseDSM's Avatar
If I may make a suggestion if your going new intake mani, look at something with larger runners to let that 2.4 breath. The magnus is a sweet piece but to small for the 2.4. I would suggest the AMS f1 if you could fine one, or a JMF manifold. The larger ports on the runners will help a ton. Plus it will push the rpm band more to the right some which will help your top end. I am planning on running a JMF drag mani on my car. Good luck with the build.
ConEvo (Mar 4, 2018)
Old Mar 4, 2018, 11:35 PM
MR ArcticC's Avatar
Your spool is bad. My 2.4LR (gsc s3+ magnus V5+fp black mhi housing) hits 300tq sooner than yours. Is your 2.4LR cam timing spot on?
Old Mar 5, 2018, 01:34 AM
CurseDSM's Avatar
Remember he is on a stock intake mani, and tb they are both choke points on a 2.4. My car makes 300 ft lbs of tq by 3500 rpms on stock tb and Rev3 ported intake mani with a turbo similar to a black.
Quick Reply: 2.4LR Evo 9 93oct Virtual Dyno Results
