Replacement top mount sphericals
Old Mar 27, 2018, 12:38 PM
BigT's Avatar
I'd like to replace the spherical bearings in my JRZ top mounts. Trying to find measurements or a part number online has come up with nothing. I don't want to call JRZ as they are probably selling them with a substantial markup. Any info on sizing or where to source from would be appreciated.
Old Mar 28, 2018, 03:08 AM
Bee-Raddd's Avatar
you could always take them in to your local bearing wholesaler they can probably eyeball them and tell you what it is. im picking they are a standard size spherical as JRZ will do that to keep manufacturing costs down.
Old Mar 28, 2018, 08:22 AM
Dallas J's Avatar
Best bet is to pull it out and measure it. Standard size would be nice but if its like Ohlin there's 2 sources I've found, one is Ohlin and their authorized repair vendors, other is bulk from china via allibaba. The former being $80 each and latter being a min order of 100. I feel like I should buy a min order at some point and just sell them for ~$5 over because $80 for those bearings is terrible.
Old Mar 28, 2018, 08:23 PM
kikiturbo's Avatar
dallas, what size are ohlins bearings? The rears more specifically..
Old Mar 28, 2018, 08:26 PM
Dallas J's Avatar
Front and rear are the same, but they are:
OD: 33mm
Ball Width: 20mm
Race Width: 16mm
IIRC, you can find the 18mm ID bearings no problem, but not with 33mm OD.
Old Mar 28, 2018, 09:01 PM
kikiturbo's Avatar
yeah, it is a weird size...
Old Mar 28, 2018, 09:03 PM
kikiturbo's Avatar
If I were you I would cut some new top mounts with more common 18x35 mm bearing.
Old May 20, 2018, 01:33 PM
BigT's Avatar
looks like they are 18x35mm. Any recommendations on which to get? Aurora? There are no part numbers stamped on these.
Old May 20, 2018, 08:44 PM
kikiturbo's Avatar
I use Fluro, but I am in EU and Fluro is german... Try Aurora, or search for Fluro motorsport units if you can find them in the USA... as far as I can see, https://mdmetric.com/ sells them
Old May 21, 2018, 08:20 AM
BigT's Avatar
Called Pegasus and gave them my measurements and they are claiming its an odd size. They had nothing in their inventory to match.
Old May 21, 2018, 08:38 AM
Dallas J's Avatar
You gotta search outside the US for those odd bearings. Found a place in UK that has a match for the size.
http://www.mcgillmotorsport.com/m18-...on-lined-6676/
Old May 21, 2018, 09:33 AM
kikiturbo's Avatar
http://fluro.de/index.php/en/product...3771-gxsw-ms-2
here, direct from the manufacturer (and you can order direct if you dont have a distributor in the US)
Old May 21, 2018, 11:40 AM
kaj
kaj's Avatar
Sub'd for resources.
Old May 21, 2018, 11:46 AM
psfp's Avatar
18x33?
https://www.rhdjapan.com/cusco-spher...g-mbwt-18.html
Old May 21, 2018, 06:46 PM
BigT's Avatar
That was quick.
Thanks for the links, guys. Lets see how long shipping will be from the UK.
Quick Reply: Replacement top mount sphericals
