Power folding mirrors on USDM Evo 8
Hey everyone
so I was wondering how hard it would be to have power folding mirrors on a USDM Evo 8. Would it be possible to get the motors and just wire it in or would you need JDM power folding mirrors? And how exactly would you wire it? Any info helps thanks
your for sure going to want to get the actual motorized units. If you tried to modify non-motorized ones it would probably end up looking like some high school science fair project. As far as the wiring goes, my gut tells me you are going to need a different etacs, but I don't know for sure. Worst case you would have to roll your own MCU solution to control them. Best case they have a built in MCU and all you gotta do is give them 12v switched to get them to unfold.
https://www.evolutionm.net/forums/ev...p-evo-9-a.html
Looks like Demon already took a look at this, and yah bad news ETACS controls them. So high school science project to get them to work lol. If it really is just a motor and a position sensor in there then you will need an H-bridge motor driver connected to an MCU through I2C or something like that and the firmware on the MCU to read the position sensor and do the P.I.D. stuff to control the H-bridge.
Yea, unfortunately it doesn't. I'm not sure if the ETACS controls the physical folding of them or just the automated folding at xyz mph
The switch on the dash utilizes the same plug, but the ETACS is the kicker. Someone a long while ago used an arduino board to control the folding but never posted any how-to on that aspect
Shame that this wasn't offered on the US cars ever
Why Mitsubishi didn't think the us market would want all the cool stuff other markets got is beyond me. If there was a good source to get these things into the US it would be worth developing a solution.
Nah you couldn't do that, you could rig up two switches, one to open and one to close. If the mirror actuator is like the hvac actuator i took apart then you can't over extend the armature so you would just have to manually open and close them with two different switches and some relays. Because you have to reverse the current through the motor you would have to set the relays up in an h-bridge configuration.
You wouldn't have to get an OEM switch and an ETACS swap, if you wanted it to work like OEM you would. Otherwise you can set something up yourself, and you could probably interface it with the factory switch too if you wanted to. That really comes down to your technical knowledge and experience though.
Been thinking about this lately. Does the evo 8/9 share the same door mirrors as the lancer 02 - 07 ? If so, we are in luck.
https://www.ebay.com/itm/Folding-Power-Side-View-Mirror-Driver-Left-LH-for-02-07-Mitsubishi-Lancer/131614797478?fits=Model%3ALancer&hash=item1ea4da6e a6:g:ehMAAOSwyXhZv8dH
edit: nvm, just read the complete add and it said "excluding evo models" and it may not actually auto fold. what a shame. I don't know if that's true though....
I would think a DEI 530T window control module might work. It has multiple inputs and can control 2 motors in 2 directions. Igntition to trigger opening and ground pulse to trigger close when car shut off/door closed/alarm armed. I've used them to control actuators in the past and they also have resistance settings as a safety so motors can't be run past their limits
EndlessRed
23
Mar 14, 2011 01:16 PM
evo8jedi
12
Feb 15, 2009 01:59 AM
Gary 805
Apr 9, 2008 10:11 AM
