Fly by wire (dbw) from evo x to evo 5
Hi guys
have anyone done this in their evo 4-6? I have seen that you can take the throttle body and gas pedal from a evo x tho.
Plug itself is probobly not available as oem part
I bought my throttle body together with plug from auto recycler, same as well gas pedal plug.
For the throttle side you could use some honda throttle connector
just need to figured out which model and year (I would look around some usdm accord about ‘12-15)
https://www.bmotorsports.com/shop/pr...oducts_id/2299
I chose NA4W pedal and throttle because cheaper than evo10. These conector is same as evo10.
Please tell me the kit that uses the evo 10 pedal for evo 7-9.
toyota 90980-11858 is fit on evo10 gus pedal and throttle.
https://youtu.be/vz-C0pZtEqU
https://youtu.be/W-phTrwO6N4
I checked DBW operation using LinkG4+ evolink.
https://trackformula.co.uk/product/m...al-conversion/
Here you go mate. There is also a kit without the pedal as well. If you find a pinout diagram for the throttle body, please let me know
I order this kit now.
Here is evo10 pinout.
4G69 Throttel is same pinout evo10 throttle.
I use 4G69(NA4W) throttle.
Fit on OEM elbow. It is a little tight.
It is the same mounting pitch.
This is APS wiring diagrams same as evo10.
Pin 1 : +5V
Pin 2 : Sensor Ground
Pin 3 : APS (Main)
Pin 4 : +5V
Pin 5 : Sensor Ground
Pin 6 : APS (Sub)
Pin 1 : +5V
Pin 3 : APS (Main)
Pin 4 : +5V
Pin 6 : APS (Sub)
