Arm Serial connection to usb.
Aem Serial connection to usb.
Ok so I have a aem serial connection in my glove box. None of my laptops have this connection anymore. So that being said I have tactrix and wanna log my car! Can I wire a usb to the serial connection or get an adapter? Id rather just wire up a usb if I knew what wire went where rather then having another connection. Guy at the store was telling me an adapter may not work. So what needs to be done?
there is actually some industry drama around the USB to serial converter cables. A lot of the stuff out there has knock off chips because FTDI who holds the patents charges a lot of their converter chip. FTDI decided to put out drivers that initially bricked all the knock of chips. This caused a lot of backlash from consumers because they were just innocent victims here, and was referred to as "FTDI Gate" . So if your cable wont work with the newest drivers chances are its an old knock off and you should probably buy a new one.
TLDR: If your USB-to-Serial converter cable doesn't work chances are its a knock off. You can either hunt for drivers that will work, or buy a legit one.
ronaldo9 (Apr 22, 2019)
