Mass Part Out - Aftermarket New Used - OE Exhaust
For SaleMiscellaneous
Price
$1• OBO
- Location Whittier, CA, 90605, USA
- Condition Used
ALL Must go, make me a reasonable offer please!
Aero/Exterior:
APR Rear Diffuser - Used - Evo 8 USDM Bumper - $350 obo Pic
C-West Front Bumper - Used - Evo 8/9 - $300 obo
C-West Front Bumper - New - Evo 8/9 - SOLD
C-West Side Skirt - New - Evo 8/9 - $500 obo Pic
OEM Gray Rear Bumper - Used - Evo 8 USDM: $200
OEM Front Headlight Set Smoked - Used - Evo 8/9 - $1,300
OEM Grommet Screw M6 MR393386 - New - Evo 8/9 - $3
OEM Rear Taillight Set Smoked - Used - Evo 8/9 - SOLD
Seibon CF Front Light Air Duct: - New - Evo 8/9 - SOLD
Voltex Front Canard White Painted Oil Cooler Cut: - Used - White - Evo 7/8/9 with C-West Front Bumper - $1,400 Pic
Voltex Front Canard - New - Evo 7/8/9 with C-West Front Bumper: SOLD
Brake/Clutch:
Brembo Slotted Rear Rotor - Used - Evo 8/9 - SOLD
Endless 2 Piece Front Rotors + CC-R Pads - Used - Evo 8/9 - SOLD
Exedy Stage 2 Dual Plate Clutch - Used - Evo 8/9 - $500
Forge Brake Duct with Hose + Inlet - Used - Evo 8/9 - SOLD
OEM Brake Pedal Assembly - Used - Evo 8/9 - $30
OEM Brake + Clutch Pedal - New - Evo 8/9 - $10 Pic
OEM Clutch 20k - Used - Evo 8 - $20
OEM Clutch Line - Used - Evo 8/9 - $40
Techna Fit SS Brake + Clutch Line - Used - Evo 8/9 - SOLD
Cooling:
Greddy Type-R FMIC - SOLD
Koyo Aluminum Radiator - Used - Evo 8 - SOLD
Ralliart Thermostat RA143463N1 - Used - Evo 8/9 - $150 Pic
Samco Radiator Hose Blue - Used - Evo 8 - SOLD
Electronics:
Apex'i S-AFC2 - Used - $240 Pic
Center Gauge Cluster Holder for 60mm Gauge - USED - SOLD
Defi 52mm Boost Gauge - White - Used - Might be Broken, not sure why there is a hole in it. Been too long to remember. - SOLD
Defi 60mm Gauge Set Link Unit + Red EGT, Red Fuel Pressure, Red Oil Pressure, Red Oil Temp, White Water Temp + Center Gauge Cluster + Radio Relocation Kit: SOLD
Defi 60mm Gauge Set Link White Water Temperature - New - $240
Denso Spark Plug Wires - Used it for less than 2 miles less than 8 months old - SOLD
Greddy Boost Controller Profec B Spec2 - Used - Evo 8 -SOLD
HKS F-Con V Pro + Harness + Sensor + Upper IC Pipe + Greddy Type-R BOV + HKS Suction Intake Pipe x 2ea + HKS Intake (no element): $1,900 Pic obo
HKS Turbo Timer + Mitsubishi Harness - Used - $50
Okada Project Coil Pack - Used - Evo 8 - $400 Pic
Ralliart Spark Plug Wires - Used - Evo 8/9 - Sold
Sun Auto Hyper Force Systems - Used - Evo 8 - Sold
Sun Auto Ignition Blade - Used - Evo 8 - $100 Pic
Engine/Performance:
A'Pexi Power Intake - Used - Evo 8/9 - $140
Buddy Club 264/272 Cams - Used - Evo 8 - SOLD
Greddy Type-S BOV x 1 + Adaptor + 1 extra for parts - Used - Evo 8/9/10 - SOLD
HKS Cam Gear Set - Used - Evo 8 - SOLD
Mitsubishi Evo 8 Spark Plug Cover MD345074 - Used - $30
OE Evo 9 Turbo - Used - Evo 8 - SOLD
OE Oil Return Line Gasket MN156738 - New - $4
OE Oil Line Gasket MR464563 - New - $4
OE Oil Filter x 7 - SOLD
Perrin Light Weight Pulley - Used - Evo 8 - SOLD
SARD Oil Catch Can - Used - Evo 7/8/9/ - $60
Tomei Arm M7960 Turbo Kit - New - Evo 8/9 - $1,200 Pic OBO
Exhaust:
Greddy Ti Exhaust - SOLD
Exhaust Gaskets 2.5" (total of 3) - New - Evo 8/9 - $20
OEM Evo 9 Catback x 2: SOLD
OEM Evo 8 Mid Pipe x 1 $150 ea
OEM Exhaust Manifold, Coated, EGT Hole - Used - Evo 8 - $100 Pic
O2 Housing to Turbo Gasket - New - Evo 8/9 - $8
Titek 3 In Titanium Cat Delete - Used - Evo 8/9 - SOLD
Titek 3 In DP Heat Coated - Evo 8 - SOLD
Titek 3 In O2 Housing - Used - Evo 8 - SOLD
Tomei Exhaust Manifold (EGT Hole Tabbed) + O2 + Downpipe + Gasket + Heat Warp: SOLD
Fuel:
Greddy/Denso 720 cc Injectors x 4 - Used - Evo 8/9 - SOLD
OEM Fuel Tank Spring Clip MB642442 - New - Evo 8/9 - $3
Fuel Pump Filter - New - Evo 8/9- $5
Sard FPR With Stainless Steel Braided Hose, Fitting, Bracket for OE Rail - Used - Evo 8/9 - SOLD
Walbro 255 Fuel Pump - New - Evo 8/9 - SOLD
Walbro 255 Fuel Pump - Used - Evo 8/9 - SOLD
Other:
B&M Short Shifter 5 Speed + Tomei Knob - Used - Evo 8/9 -SOLD
Battery Relocation Kit Including Wires, and Kill Switch - Used - Evo 8/9 - SOLD
Billet Engine Mount Left + Tranny 5 Speed + Roller Stopper - Used - Evo 8/9 - $130
OEM Crank Side Cover MR447734 - New - Evo 8/9 - $35
OEM Engine Mounts Top Left, Tranny 5 Speed _ Roller Stopper - Used - Evo 8/9 - $180
OEM Gas Pedal Assembly x 2ea - Used - Evo 8/9 - $30
OEM Subframe - Used - Evo 8 - $200
OEM Holder Light Panel MR402645 - Used with Alarm Drilled Hole - $5
OEM Door Handle Cap MR794191 - New - $4
Setrab Oil Cooler - Used - Evo 8/9 - SOLD
Sparco 13 In Suede Steering Wheel + Splash Wheel Hub - Used - Evo 8/9 - SOLD
Sparco 3 In 4 Pt Harness Black - SOLD
Sparco 2 In 4 Pt Harness + Shoulder Pad - SOLD
Sparco 2 In 3 Pt Harness - SOLD
Suspension/Wheel:
Beatrush Rear Strut Bar - Used - Evo 8 - SOLD
Beatrush Roll Stop Mount - Used - Evo 8/9 - SOLD
Beatrush Propeller Shaft Mount Bushings Billet - Used - Evo 8/9 - SOLD
Buddy Club Seat Rail Set Driver + Passenger + Bride Copy - New - Evo 8/9 - $180 Pic
Carbing Front Strut Bar - Used - Evo 8 - SOLD
Carbing Lower Arm Bar - Used - Evo 8 - SOLD
Cusco 25mm Front Sway Bar - Used - Evo 8/9 - $160 Pic
Energy Suspension Bushings 5.3133G + 5.18115G - New - Evo 8/9 - SOLD
OEM Evo 8 Wheel - USED - Evo 8 - SOLD
Progressive 27mm Rear Sway Bar - Used - Evo 8/9 - $130
Tanabe Front Under Brace - Used - Evo 8/9 - $160 Pic
Tanabe Rear Brace - Used - Evo 8 - SOLD
Team Dynamic FQ400 Wheels with Falken Tires x4 - Used - Evo 8 - SOLD
Whiteline Rear Endlinks - Used - Evo 8 - SOLD
Zeal Function X Coilovers + Extra spring - Used - Evo 8/9 - SOLD
