Evo GeneralDiscuss any generalized technical Evo related topics that may not fit into the other forums.
Please do not post tech and rumor threads here.
I need to perform a coolant system / radiator flush. I have attached an image diagramming the parts. #18 is listed as the “engine coolant outlet.” Back in the day, we always called it a water neck. #20 is the thermostat. #18 is the thermostat housing. There must be a gasket or o-ring or something between the “engine coolant outlet” and the thermostat housing. Does anyone here know the part number for the gasket or o-ring or have a source? I have searched the web, but have not been able to find anything.
I have a yellow 2003 Evo 8 with just a bit over 67,000 miles. I bought it new in 2003. Thanks for any help that you can provide me.
Never mind. I see that the thermostat has a built in seal. I guess I should replace the thermostat after 23 years, if I am going to perform a coolant system flush.
