South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
JIC coilovers
Old Nov 17, 2005 | 03:23 PM
dcaudio's Avatar
JIC coilovers
Brand New!!! Set of JIC coilovers now in stock for $1,000.00. Regular retail on these bad boys are $1,250.00. Please PM me your zip code so I can give you a shipping price.
Thanks,
Dave
Installation: The kit includes all required components and hardware for a complete installation.
- 15-Way Adjustable Dampening
- Duralumin 6061 Lower Seat
- Cool-Bend Chrome Silicon Metal Linear Rate Springs
- Aircraft Aluminum/Hard Steel Brackets
- Inverted Monotube 40-45mm Piston Dampers
- Anodized Aircraft Aluminum Pillow Ball Upper Mount
- Adjustable Height from ½ to 3-inch Drop
- Rubber Bump Stops Prevents Bottoming Out
Old Nov 17, 2005 | 03:25 PM
dcaudio's Avatar
Also I forgot to mention that this deal is only for a limited time. My wholesaler just dumped these on me.
Old Nov 17, 2005 | 07:41 PM
ez's Avatar
ez
I assume these are the FLT-A2's? I run them on my car. Bump for a great product...
Old Nov 17, 2005 | 09:00 PM
Mr. Slappy's Avatar
Cant be a2's because they retail for $1600. Probably a1's.
Old Nov 18, 2005 | 06:53 AM
ez's Avatar
ez
True, but the A2 is the only one that is 15-way. The A1 is fixed dampening...maybe they meant 5-way and they are the SA1
http://www.jic-magic.com/productsjic_susp.htm
Old Nov 18, 2005 | 10:38 AM
dcaudio's Avatar
yes these are a1's, sorry for the typo
Old Nov 25, 2005 | 11:05 AM
dcaudio's Avatar
anyone interested in a set?
Old Nov 25, 2005 | 11:07 AM
dsevo's Avatar
Let me know when you can get a great deal on a-2's. Thanks
Old Nov 25, 2005 | 11:59 AM
dcaudio's Avatar
It would be $1570 for the A2's
Old Nov 25, 2005 | 08:48 PM
KevinD's Avatar
now heres the question: when they say 15-way adjustable damping, what the hell does that mean? does that mean they can adjust compression and rebound each with 7 and 8 "clicks" each respectively?
or do they actually have 15 different independent adjustments, of which no one would have any clue what they actually do...?
Old Nov 26, 2005 | 10:17 AM
dcaudio's Avatar
The FLT-A2 features lightweight, 15-way adjustable inverted monotube 40/45mm piston dampers that ensure high strength and fade free performance.
Old Nov 27, 2005 | 07:32 PM
ez's Avatar
ez
15 total detent settings for the non-independent compression/rebound. Independent spring length, spring preload, shock body length (ride height), and mounting bracket length adjustments.
downforceinc
Evo 'For Sale' Suspension / Brakes / Handling
18
Jan 5, 2009 11:34 AM
downforceinc
EvoX 'For Sale' Suspension / Brakes / Handling
Nov 25, 2008 11:47 AM
Vivid Racing
May 13, 2005 09:45 AM
Vivid Racing
Jan 11, 2004 09:24 PM
Vivid Racing
16
Sep 12, 2003 09:18 AM
