South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
need help with manifold removal
Old Mar 18, 2006 | 07:22 PM
asasin79's Avatar
looking for someone or a shop that can remove nuts that have 3 of 6 sides accessable and those 3 sides are slightly stripped. i don't care if the nuts are snapped, cut or broke as they're already stripped and need replacing. very tight work space. i've used every tool i have access to and can't seem to get them.
thanks
Old Mar 19, 2006 | 05:56 AM
EvoG8r's Avatar
LOL, I just stripped a nut between the manifold and O2 housing and I can't get the nut back in!
Sounds like they will need to be drilled out and retapped for you. Check with Alamo or post on Dallasimports.net. They may have some ideas for you.
