South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
The truth about K&N air filters
Old Jun 23, 2006 | 02:27 PM
mrMTB's Avatar
Exclamation The truth about K&N air filters
Might give you pause next time you're looking to spend some $ on your car...
http://home.usadatanet.net/~jbplock/ISO5011/SPICER.htm
Old Jun 23, 2006 | 07:47 PM
EvoBig16G's Avatar
cliffnotes?
Old Jun 23, 2006 | 07:54 PM
derangedazn's Avatar
I think I need to freshen up on my calculus and quantum physics to understand what that thread was talking about
Old Jun 23, 2006 | 07:57 PM
Dayton_EVO's Avatar
Sounds like GM paid big money out to make sure their filters showed better than the aftermarket ones. Don't read too much into it. I worked for GM for years and know how they try to run this game about OEM being better than aftermarket. I run K&N in all my vehicles and K&N by far exceeds OEM filters if oiled right.
Old Jun 23, 2006 | 07:59 PM
Boltz.'s Avatar
FCOTM Winner
^ You have no idea what you are talking about.
This test was done quite a while ago and the results speak for themselves, the Paper AC delco filter outperformed all other filters. Paper filter = win
Old Jun 23, 2006 | 08:00 PM
Dayton_EVO's Avatar
Yeah right, keep thinking that. You run the OEM filter all you want, your choice. My K&N's have out performed every OEM filter including AC Delco in all of my GM vehicles and that is a fact.
Paper filter = win
Yeah, for the OE factory parts department.
Old Jun 23, 2006 | 08:01 PM
first look at who is sponsoring the research. If I am a big company performing the research, of course I am going to skew the results in their favor.
Old Jun 23, 2006 | 08:04 PM
Dayton_EVO's Avatar
+1
and I used to work for them so I do know their tactics very well.
What do they say? uhh... Paper filters are for coffee.
And all from a guy that was supposedly an expert of what and he says this in his article....
Gentlemen and Ladies, Marketing and the lure of profit is VERY POWERFUL! It is amazing how many people believe that better airflow = more power! Unless you have modifications out the wazoo, a more porous filter will just dirty your oil! Some will say " I have used aftermarket brand X for XXX # years with no problems. The PROBLEM is you spent a chunk of ching on a product that not only DID NOT increase your horsepower, but also let in a lot of dirt while doing it! Now how much is a lot? ANY MORE THAN NECESSARY is TOO MUCH!
The stock filter will flow MORE THAN ENOUGH AIR to give you ALL THE HORSEPOWER the engine has to give. And this remains true until the filter is dirty enough to trip the air filter life indicator. At that point performance will decline somewhat.
Anyone else see the fallacy or flaws in some of this BS.???
Old Jun 25, 2006 | 06:22 AM
EvoG8r's Avatar
It's just like tobacco companies doing research to show smoking doesn't kill you.
Old Jun 25, 2006 | 07:43 AM
mrMTB's Avatar
Dayton, you might try rereading the article.
1) The research was not sponsored by GM; the persons doing it were diesel enthusiasts, one of whom happened to work at a facility that had access to the tools to perform these tests.
2) All of the filters tested were purchased at retail by other deisel enthusiats and donated to the project.
3) The initial restriction (in in/H2O) ranged from a low of 4.54 for the K&N to 6.23 for the AC Delco (hereafter AC).
4) All filters were subjected to an ISO 5011 test to measure the amount of time and particles required to reduce the filter to its initial restriction + 10 in H2O. The K&N filter ran for 24 minutes before hitting this point, and the filter passed 7.00 grams of test particles through the filter in that time. The AC filter ran for more-than 60 minutes, while only passing .40 grams.
5) Based on the (4), the K&N filter held 211.6 grams of material before hitting the restriction limit. The AC filter help 573.9.
Now the good part...
6) Despite the much lower initial restriction, after less-than 200 grams of dust was delivered to the filter, the flow restriction of the K&N filter exceeded that of the AC.
From the article:
It’s interesting to note the shape of these Dust Loading Curves. The AC and Baldwin filters each had near linear responses until reaching maximum restriction. Restriction for these filters increased at a constant rate versus the 9.8 gms/min dust feed rate. The other filters, most notably the oiled reusable types, had an exponential loading response before reaching maximum restriction. These filters had a lower initial restriction, but they became exponentially more restrictive under a constant flow of dirt. Also notice the length of the curves as it shows the relative test time for each filter (time to max restriction).
In summary, it would appear that _for this particular filter_, K&N's marketing materials do not stand up- it does not function as well at filtering air as the OEM part. Additionally, after a relatively short period of time your oiled gauze type filter can be performing more-poorly than an OEM filter. While K&N does publish their estimated HP gains for filters on their website, you must write in to ask them for a copy of their ISO 5011 testing results.
Based on the above, also, I would suggest that K&N's stated service interval of 30-50k miles is too long ensure adequate performance of their filters.
Old Jun 25, 2006 | 08:20 AM
Monkey's Avatar
That's why I just skip using an air filter and run a pair of pantyhose
(this post is meant as sarcasm)
Old Jun 25, 2006 | 01:37 PM
brooks1005's Avatar
I see this as a dirt filtration test and not a test to see who flows more absent of dust.
Old Jun 25, 2006 | 03:06 PM
chase123's Avatar
My dad is a diesel mechanic, and told me the exact same thing this study shows. I never was sure if he was right, but this definately confirms his theory.
The graph shows that the K&N flow more when absolutely clean, but as the dust grows past 190 gms the flow begins to drop tremendously compared to the paper. The study also showed that the K&N filter passed 7.00 gms of the test particles while the paper only passed .4 gms. That is 1750% more particles getting the opportunity to damage your engine.
These highly porous high flow filters are great for race cars who clean or replace them every race, and expect to replace engine parts all the time. For those of us who want a filter for daily driving, K&N isn't the way to go.
Old Jun 26, 2006 | 08:04 AM
KevinD's Avatar
for starters, i would like to point out if you are retarded enough to let your filter accumulate 1/2 a pound of dust without cleaning it, you deserve to have the 7 grams of dust pass into the engine.
for the AC delco filter, it had well over a pound of dust in it!!!! seriously... does anyone ever allow it to get that bad?
so even if we look at the results from a realistic perspective, and assume those results are not flawed in anyway, the results are telling us exactly what everyone assumed!
the K&N has less of a pressure drop then the OEM filter. this means your engine doesn't have to work as hard to suck air in. this IS a performance gain. obviously if a filter is going to flow more air, you are going to have a more porous filter, and more dirt going into the engine.
moral of the story? K&N filters DO make more power then OE (although it will be debatable as to how much), but at a cost of less filtering. the effectiveness of the filter will remain strong provided regular maintance and cleaning of the K&N type filter, while the OE MUST BE REPLACED.
Old Jun 26, 2006 | 08:15 AM
dridge11's Avatar
<---- Just noticed your last comment.
<---- Removing pantyhose mod when he gets home.
