South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
Help.....
Old Jul 16, 2007 | 11:12 AM
dzraduzit's Avatar
Help.....
Well now I gotta figure out what's wrong w/ my car..... I took it down lime creek rd. pushed her pretty hard. On the way home sitting at lights the idle started jumping up like 500rpms every second and the boost feels weak. Is it possible for a boost leak to affect the rpms like that?
Old Jul 16, 2007 | 12:33 PM
Whoosh's Avatar
Check all of your vacuum lines.
Old Jul 16, 2007 | 02:27 PM
j8's Avatar
j8
Like whoosh said check you vacuum lines. Also check all your charge pipe connections and make sure they are secure. Your car will run like crap if one of your vacuum lines or charge pipes are loose or completely off. It will smoke out the exhaust pipe also if you get on it. If everything is secure for sure then check your plugs. Then the almighty compression check.
Old Jul 16, 2007 | 02:46 PM
93turbomax's Avatar
Or as Whoosh could tell you, make sure the settings for the tune are right. If not you might want to skip straight to the compression test.
Old Jul 16, 2007 | 03:51 PM
milo's Avatar
True dat
Old Jul 16, 2007 | 03:55 PM
dzraduzit's Avatar
Originally Posted by milo
True dat
I'll also have master milo take a look, I figure he will know about vacuum hoses since he sucks so well!
Old Jul 16, 2007 | 04:02 PM
05r6's Avatar
you have a vacuum leak, fix it.
Old Jul 16, 2007 | 06:46 PM
dzraduzit's Avatar
hmmmm.... If I just got a custom tune a week ago, should I be worried about the settings for the tune? Man I need to go to wyotech. Sorry for asking noobish questions.
Old Jul 16, 2007 | 07:31 PM
j8's Avatar
j8
Check all your connections first. It is most likely something simple. Don't get to worried until after checking everything. If you can not find anything simple then like I said compression test is next. Little things can seem like all hell is breaking loose. The person who tuned your car I hope would tune it a little on the safe side, which I am sure he did.
Old Jul 17, 2007 | 01:44 AM
dzraduzit's Avatar
Yep, tuned by chris at ams, was only running 20psi, on my set-up. Pretty safe.
Old Jul 17, 2007 | 06:51 PM
dzraduzit's Avatar
Found the problem, the seam weld on my intake manifold gave. I let the car run, tapped the throttle from under the hood and listened to where it was coming from. I could see the seam separating a little everytime it made a whistle sound. I'll be taking it off and getting it welded together shortly, the ****ty thing is, that I just put my other car in the shop today for an a/c compressor. when it rains it poors.
Old Jul 17, 2007 | 09:15 PM
j8's Avatar
j8
Good to hear is was something well not real simple, but a lot better than something else.
Old Jul 18, 2007 | 07:41 AM
Xfer's Avatar
+2
Old Jul 18, 2007 | 10:04 AM
dzraduzit's Avatar
Forgive me! I tried JB weld as a temporary fix, we'll see how good that stuff is, put it on last night. Louie gave me the idea. I am now ghetto.
Old Jul 18, 2007 | 10:15 AM
Whoosh's Avatar
JB Weld>bubble gum!!!!!!!!!!!
