wtb: brake pads
Old Nov 10, 2007 | 05:04 AM
reggiesd's Avatar
wtb: brake pads
kelly's the only one who's get them so far but i wanted to see if anyone got any descent used brake pads i can get..i just need to change my front set. i don't drag race or auto x at the moment so i just need a good set good enough for daily driving. thanks!
Old Nov 10, 2007 | 11:07 AM
nikkadanny's Avatar
same here, looking for some
Old Nov 10, 2007 | 03:44 PM
ninja808's Avatar
**The Porterfield R4S pads I had were sold.**
You guys missed out on some badass brake pads...
Old Nov 11, 2007 | 07:23 AM
mrMTB's Avatar
Also, I was speaking to the owner of Girodisc the other day, and he is selling a stock-like compound brake pad with the adhesive shims installed. If I recall correctly, he said that they would be $100 for all four corners.
Old Nov 11, 2007 | 09:11 PM
reggiesd's Avatar
$100 for front and rears? that's cheap! how do we get a hold of him?
Old Nov 12, 2007 | 06:03 AM
mrMTB's Avatar
http://girodisc.com/catalog/contact_us.php
Old Nov 13, 2007 | 11:55 AM
Girodisc Martin's Avatar
Yes we do have pads for the Evo priced at $100 for the car set. They are actually very good pads, better than stock when it comes to initial bite, noise and dust. They bed in very easily and are far less likely to produce a "warped rotor" feel than the stock setup. They come with anti-squeal shims already installed on the back. They are a Semi-Metallic pad meant for street use, these are not track pads. We have a few sets left in stock.
We also have Axxis Ultimate pads which go a couple hundred degrees higher, but are more prone to noise if not bedded properly. An excellent overall performer with even higher initial bite and a great price point at $150/car set. Ferodo DS2500's are available, go even a little higher in temp than the Axxis and have a bit more bite and a lot more dust. About as high end as you want to go comfortably on the street. They run $300ish/car set.
You can contact us at 949-350-6194 or sales@girodisc.com
Thanks,
Martin
Old Nov 13, 2007 | 02:14 PM
reggiesd's Avatar
sent yah an email..but if you don't get to check...how do i buy them from you?
