South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
Does anyone play Live For Speed? (LFS)
Old Dec 6, 2008 | 08:15 PM
goofygrin's Avatar
They have a rallycross track
LFS + Logitech G25 = schmex
I can't convince the wife that I need one of those
Old Dec 8, 2008 | 08:39 AM
Evo_Someday's Avatar
XF GTI Setup for Live For Speed
Yeah - and an autocross track too! Need to unlock the game to do that one though.
Ok so I've been playing a lot this weekend and learning a lot too. I've been racing in the FWD hatch group and have gotten decent and was able to run 1:38 with the following setup. It handles significanly better than the default setup. I find it very easy to drive and also won't lock the front wheels so you can lay on the brakes full into the turn. The key with this car is to do all your braking before the turn and just baby the accelerator through the turn then hammer it on the straights. Pretty standard stuff actually.
Also another tip -- when racing, press the number 4 on your keyboard and it will show you the racing line with the braking points. Nice learning tool!
XF GTI Setup for Live For Speed 2
Info
Fuel load at start: 7% possibly as low as 5% for a 4 lap race.
Brakes
Maximum per wheel 600 Nm
Brake Balance (front) 73%
Suspension
Rear
Ride Height Reduction (motion range 0.051 m)
Stiffness 75.9 N/mm
Damping 9.3 Ns/mm
Anti Roll 60.0 N/mm
Front
Ride Height Reduction (motion range 0.060 m)
Stiffness 63.6 N/mm
Damping 10.9 Ns/mm
Anti Roll 76.0 N/mm
Steering
Front
Maximum Lock 30.0
Parallel Steer 50%
Toe in -0.1
Rear
Toe In +0.1
Final Drive
Front Clutch Pack LSD
Locking 70%
Preload 500 Nm
First 4.14
Second 2.83
Third 2.17
Fourth 1.79
Fifth 1.47
Final Drive Ratio 2.97
Tyres
Manufacturer Bridgestone
Front: ROAD_NORMAL
Pressure 27.1 psi
Camber Adjust -5.4
Rear: HYBRID
Pressure 29 psi
camber -4.5
Old Dec 8, 2008 | 08:55 AM
element26's Avatar
i might have to try this when i get home looks like fun
